neon sign transformer confusion
Started by Tesluh, October 25, 2016, 12:08:02 AM
Tesluh
after about an hour of trying to read the part number off the nst I found  hm106nd  and ordered one each of these.  they come with the terminal (same as the bertonee don used).
https://www.amazon.com/Neon-Transformer-Signs-Devices-6-5kV/dp/B00OYZSMM0
http://www.ebay.com/itm/Neon-Transformer-for-Signs-Neon-Devices-120v-50-60Hz-0-7A-6-5kV-50mA-/262467328300
if anyone knows where to find those capacitors in stock I would be grateful.  everywhere I looked that offered them showed no inventory and they are 9 weeks to have them built.  Or similar construction one?  Don could have easily found others and yet he sought out those...
Magluvin
Quote from: Tesluh on October 25, 2016, 08:08:16 PM
You could use other caps series/parallel.  Like look for 1kv and configure 4 in series for 4kv. There should be 1kv available. 4kv and up tends to be way specialized. And just like he has 2 of those caps in parallel, it shouldnt be an issue to put together your own caps. So you need 2uf total. If you can find 5uf 1kv caps, then 5 in series which brings us to 5kv for the heck of it. And another bank like that and parallel them you have 2uf. Just an example.  I would stick to poly caps as shown in the pic. They tend to have great characteristics for this stuff.
Mags
Mags
Tesluh
Thank you, from another close up of Dons actual board I read they were .1uf each 4kv, so .2uf is what I will shoot for.  if it doesn't work I can hunt down the exact ones.  for 5 pcs they were going to be $50 ea!
  Going to order 4 of these and try 2x2 series and parallel for .2uf@6000vdc
http://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/940C30P1K-F/?qs=sGAEpiMZZMv1cc3ydrPrF1fw9wOI4QJULLduHe1Tl50%3d
Tesluh
Anyone know what diodes those are?  I have these coming http://www.ebay.com/itm/151368531662 they are 40ns diodes.
Zeitmaschine
