LCAP (Again) Possible Free Energy. (Voltage Gain Over time)
Started by TheGeneralHackr, October 28, 2016, 11:57:07 PM
itsu
I installed a 39uF tantalum capacitor instead of the 470nF poly.
The frequency did not deviate much.
After 2 days running i have 5.085V in the batteries, so 2mV lower.
Itsu
TheGeneralHackr
Quote from: itsu on November 09, 2016, 05:14:13 AM
Itsu
Sorry I haven't been posting lately, I've been busy.
About the MV loss. Why don't you try the circuit the way you had it to start with when you had voltage gain
TheGeneralHackr
Quote from: TheGeneralHackr on November 09, 2016, 01:50:13 PM
I'm still working on getting a oscope
itsu
TGH,
no problem, i have it running here at the side, so take your time.
I believe te earlier voltage gain seen was due to the battery chemistry.
When you load a battery, which i did during the first tests were i had to find the correct coil connections etc., the voltage will rise momentarily when the load dissappears or decreases.
After a while the voltage will stabilize again and will drop under the minimized load as it does now.
So either i did not find the correct setup yet, or you also suffer(ed) from this battery effect.
Regards Itsu
TheGeneralHackr
Quote from: itsu on November 09, 2016, 03:04:18 PM
TGH,
Regards Itsu
You must not have found the correct setup yet, but I feel your getting close. Specific coils will only work.
Your voltage gain was the start of something, I have that same voltage gain but it keeps on going. Here's a link to a video I made awhile back showing some of that. http://youtu.be/Nz04HKLBrYU
Note: That's my original circuit just moved to a different prototype board, also the 1.5v battery you see in the box is not connected at the moment.
