InnovaTehno.eu Free Energy Device - a big Fake or the real thing ?
Started by hartiberlin, October 31, 2016, 08:35:37 PM
Zeitmaschine
has anyone a clue what is this Dresden 1943 experiment about?
Innova Tehno 1943 mentions (unconfirmed) an aircraft named »Die Glocke«.
From »Disc Aircraft of The Third Reich«:
The most sensational piece of information on Nazi secret research to come out since the reunification of Germany - indeed, since the origins of the Nazi "UFO" Legend itself- is the story told by Nick Cook in his Quest for Zero Point, which appeared in the U.K. in 2001. The story is, additionally, the only real solid piece of corroboration of the Nazi UFO Legend to appear since the war, based, as as it is, on a secret and recently declassified Polish war crimes trial affidavit of a former SS general.
"The Bell" (German: die Glocke) represented something at the very pinnacle of Kammler's grizzly and super-secret SS "wonderweapons" empire. Cook's book represents the only publicly accessible information on this bizarre object in the English language, the equally macabre experimentation that surrounded it, and the stringent security the SS held it under.
The following are the salient features of The Bell, according to Cook:
(1) The Bell was reportedly a metallic object, approximately 9' in diameter and 12-15' tall;
(2) It looked like a "Bell", hence its codename to the Germans, die Glocke;
(3) It was comprised of two counter-rotating cylinders, rotating a purplish liquid-metallic looking substance code-named "Xerum 525" by the Germans, at high speeds;
(4) "Xerum 525" was apparently highly radioactive, being purple in color, and housed in cylinders with lead lining 3 cm thick;
(5) The Bell apparently required high amounts of electrical power in its operation;
(6) During use, it could only be run for approximately one to two minutes, as it apparently gave off strong radiation and/or other electromagnetic or unknown field effects;
    (a) Several scientist died on its first operation;
    (b) Subsequent tests included various plants and animals, all of which decomposed into a blackish goo and without normal putrefaction, within a matter of a few minutes or hours after exposure to its field effects when in operation;
    (c) Technicians near the Bell during these experiments reported metallic tastes in their mouths after being exposed to it;
    (d) The chamber in which the Bell was tested was lined with ceramic bricks and rubber mats, and had to have its rubber matting removed and burned after each test, and it was subsequently washed down with brine by inmates from nearby concentration camps;
(7) All the scientists and witnesses who saw or worked on the Bell were murdered by the SS as the war neared its end;
(8) The Hell [typo? Freudian slip?] was transplanted out of Silesia to a destination that has never been discovered. The Bell, along with General Kammler himself, simply disappear entirely from history, never to be seen again.
(9) A strange "henge" like structure was constructed by the Germans out of reinforced concrete near the facility where the Bell was located and tested (Muzeum Molke, 120 Miles from Dresden?). This structure resembled a test rig for the possible test of extremely powerful propulsion devices.
So what is this all about? Does the Innova Tehno device run on (radioactive) Xerum 525? Or is the Innova Tehno device the free energy device that powered »Die Glocke«, because it required high amounts of electrical power?
All this is very confusing. But maybe that's the sole purpose of it.
Something more simple:
TOMD: "How can you be so sure of that?" An deep understanding of basic physics.
That understanding of basic physics is needed here:
I'm still waiting for a (conventional) explanation how a capacitance of just 3.8nF can lower the power consumption of a high voltage transformer running at 50Hz over ten percent, other than the capacitance itself acts as (an additional) power source (see Aspden).
High and Low Voltage Capacitors (Free Energy) Test
Although this website is called overunity, strangely almost no one seems to be interested in the investigation of a simple configuration that could easily bring up evidence of zero point energy. No comments, no known replication attempts so far. One could wonder why. But if this is indeed just standard behavior of a capacitance connected to a transformer then what could be its mathematical equation? Voltage times capacitance equals negative resistance? Something like that perhaps?
citfta
Quote from: Zeitmaschine on February 16, 2017, 09:10:35 AM
http://www.electronics-tutorials.ws/filter/filter_1.html
Zeitmaschine
Means what?
It says: »Capacitive Reactance varies with the applied frequency so any variation in supply frequency will have a big effect on the capacitors, "capacitive reactance" value.«
But here the frequency stays constant at 50Hz, it is the voltage that varies. The formula for resonant frequency calculation does not include voltage, just capacitance, inductance and frequency. An arbitrary capacitance does not lower the power consumption of a 230V (isolation) transformer.
memoryman
"An arbitrary capacitance does not lower the power consumption of a 230V (isolation) transformer." Read up on 'reactive power' vs 'real power'.
forest
classical urban legend where all the persons die not having a chance to tell the story :-)
