Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Floor
@deiter
        I think maybe your theory has some valid elements to it. I don't
have a better one.
      but in contemplating the magnetic field I come up with this model.
A simple mobius strip has only a single 1/2 twist in the ribbon....but also a mobius strip
can have many twists rather than just a 1/2 twist.
The edges of a twisted ribbon have the form of a double helix.
The forces (torque and tension) are said to tend to seek their most relaxed state at all
points.  but this does not result in an even distribution of twist along the length of the ribbon
within a mobius strip.
             but rather
In the "natural form" of a multi twist mobius strip we find that most of the tight twists lie together...
while also an other section of the strip which has very little twist lies all together (no tight twisting spots to break it up).
              bloch wall
If we look at the field of a permanent magnet, and at an individual  line of force (an idealized
simplification) as having the form of a mobius strip  ...  and we place lines between the two helixs
(like the ladder rung like connections in the DNA molecule)  .... and we assign a N/S magnetic
polarity to these "rungs" like pole next to like pole ...  (all N poles connected to one helix
and all south poles connected to the other helix).  Note... that this does not necessarily result in
like pole in close proximity to each other.  Also consider that there would be other twisted ribbons
all  around in the over all field.
Where the double helix is tightly wound we will find an absence of NET magnetic force, because
N and S forces are in a near balance in any direction from we approach the double helix...except
as we approach it nearly straight on to the end of that double helix.
We have next, then to look at what Theoria Apophasis has termed the dielectric inertial plane
/counter part to the bloch wall.... in the part of the magnetic field which is exterior to the
[permanent magnet.  Lowest density in the field ... largest area.
Also we must again consider multiple force lines ... a gentle spiraling and... spiral ribbon layers
within layers  (shells) .... and also more than one ribbon sharing a single "shell".
I don't know if this model of mine gives you any ideas,  but I hope it may/
        floor
dieter
As a Sidenote: I just said the seconary field of induction increases the DC resistance in the conductor and that causes energy loss... not very logical at first glance, right? But if you force the device to maintain the current flow at the same level, regardless of higher resistance, then it makes sense and we understand how energy gets lost.
Anyhow, in any AC operation you also have to deal with the phase shift, but that may lead us to far away from the topic.
dieter
Very interesting, Floor. Very close to my own interpretation. And good you are focussing on the magnet side, I tend to drift into electrical stuff.
At the nexus of my magnet force rectifier, the bloch wall, may be a focus in which as you said, polarities are so dense that due to molecular scale forces practically equalize.
But is there a particle, the magnetron? That is ejected out of the pole with a slingshot accelleration? But why does it return to the other pole? May there be a particle-pair fission and entanglement? One particle is shot out one side, the other one the other side? As they lose monentum, and repelled by like particles around them, the build the mushroom field, with one goal: to reunite with their entangled brother particle? Maybe.
If there is a helix pattern in the magnetic mechanics, then it must cause a gyroscopic force. That would explain, why electrons interlock with magnetic fields and are forced into rotation... at 90 degree angle...! Wow Floor I think you just put in the missing puzzle piece in my theory. Thanks! We should share that freakin nobel prize I'd say :)
dieter
Hmm, there is also a further, easier explanation (sorry, on electrons again):
Electrons have a south and north pole, like our planet. Not surprising then, when they align to a magnetic field. But, according to my theory, due to their natural spinning, I call it screw-like, you'd probably say helix-guided, they then propagate in the conductor.
But ok, back to magnetism.
I think the perfect magnetic gate were, if you could sneak your rotor magnet into the bloch wall of the stator magnet and then give it a slight push so it will be repelled. But would that be possible? Just, very basic mechanical challenge? I lean towards Yes. Maybe we could use quantum tunnelling to transfer electrons into the bloch wall, would that be cool? Ok, we'd need the CERN to do the first testrun and maybe a Megawatt. But particle tunneling is real. We can Scotty-like beam particles, jumping like one inch in zero time. And the magnet would shoot out the electron or other particle.
Well just one way to sneak into the bloch wall.
A practical application of the theories is always the thing that's driving me.
sm0ky2
The DNA helix is a good analogy. If this twisted helix
Leaves one pole and twists around towards the other
The chain of N moving one way, the chain of S moving
The other way
But lots and lots of these that accumulate to the large field
They lock together when you have multiple magnets
And you can bend them, build up pressure, and let them
Explode.
You can even stick the magnets together in a certain way
So they are always under pressure. And adding just one
More magnet, say from a passing rotor or cart,
Can cause them to explode. Magnetically speaking.
