Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
citfta
Hi Norman,
Thanks for your comments.  I understand what you are saying about force times distance.  In this case the distance is the same for the repelling force as it is for the reset force.  So they cancel each other as far as I can tell.  I do think this can be made into something that will run itself and I have some ideas for how to do that.  I also believe that the same configuration on the other end of the shielding bar could more than double the output.
As far as the silly comments from Armcortex,  you just have to consider the source.  Since he has never actually built anything his comments are worthless.  I doubt he could even build a cube with a whole box of Legos.
I am looking forward to your progress and I understand about the slow pace.  I also had heart problems a few years ago and could hardly even walk across the room without resting.  Fortunately my problem was solved with a pacemaker.  I can now work most of the day without problems.
Take care,
Carroll
norman6538
Carroll I commend you for your civility and commonsense.
And I wish you great success. We all need a better form of energy.
I really appreciate these forums where we can work together where the
sum of the parts can be greater than the parts separately.
The problem I struggle with now is two repelling magnet have
a dish shaped field of force such that when they are close they
are below the repel portion of the dish and will attract but
my linear version should take me were I need to go.
Norman
ARMCORTEX
No, no, no... Stop being stubbon, stop these squirmings.
Try this instead, its the only "standard aproach, easy to understand" approach that should be investigated, in my simulation the freewheel weight was never launched, it simply had a motor with  rpm and torque, no launch energy was provided. The wheels were all turning and pushing by using centrifugal force only.
No other situation, magnetic, mechanic or otherwise, will ever ever work.
https://overunity.com/18226/physicist-needed-will-this-self-loop/msg538953/#new
The rest, is all non standard, way over your head, we need a massive breakthrough from someboy else, like Rakarsky or something.
If a pulse method, can maintain a cohesive phase/frequency relationship, pulse can be turned into H.P, many HP, it will be size efficient.
Turn the input pushes of the swinging children into rotation force.
The discussion is over, I will let Rakarsky and Stivep educate you henceforth for other non-standard approach.
ARMCORTEX
Quote from: citfta on September 12, 2019, 06:48:18 AM
Hi Norman,
Thanks for your comments.  I understand what you are saying about force times distance.  In this case the distance is the same for the repelling force as it is for the reset force.  So they cancel each other as far as I can tell.  I do think this can be made into something that will run itself and I have some ideas for how to do that.  .
Take care,
Carroll
No you dont, its all confused and probably will get exponentially complicated as you really uncover why it doesnt work then you start patching your little leaky boat in a storm, sorry in the end of the day it will not work.
I know, you know, everybody knows.
"I do think this can be made into something that will run itself and I have some ideas for how to do that."
No...You are confused and dazed, you have not even made up the basic structure of the idea, never mind the calculations.
This is standard approach, I have already presented the best of the standard approach.
Theres a ton of non standard patents to try, like the TPU and Kapanadze, these works with something else.
norman6538
ARMCORTEX  I will not waste my time getting into a verbal battle. My bench time is much more important and productive. I do my bench work and present the results.
I am very slow due to many activities and poor health.
I have seen many a good idea that had no measurements like the Milkovic pendulum.
Norman
