Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Floor
@ aye aye
Why don't you do a topic to put up your ideas on ?
                                                   Newton's magnets
                                              Equal and opposite forces.
It requires the same energy expenditure to pull two magnets in attraction apart,
as those magnets delivered during their attraction to each other.
                     But also
Because Newtons laws are valid, and because of the  two pole nature of permanent magnets...........
We can change the positions of two magnets, which are in close proximity to one another,
without doing work against the magnetic forces between those  magnets.  To see an example of this illustrated,  open the PDF attached below.
1.  To see Newton's magnets actually done, watch this video, titled "amazeing"  @
        https://www.dailymotion.com/video/x6gzr2q
2. or this variation of the Newton's magnets, watch this video, titled "RtAngSld"   @
        https://www.dailymotion.com/video/x59r978
3. or to see a completely different method of neutralizing magnet force as in this video, titled "TDForceDiagramed"
                           at 2 minutes and 50 seconds into the video watch
        @   https://www.dailymotion.com/video/x6wfk0d
4. or watch this video titled "direct approach"  @
        https://www.dailymotion.com/video/x6xgiez
5. or this video titles "Floor's brute force neutralization part 1"  @
        https://www.dailymotion.com/video/x7f0md2
6. or  this video titles "Floor's brute force neutralization part 2"  @
        https://www.dailymotion.com/video/x7f0o4w
                                   SEE THIS PDF BELOW
https://overunity.com/18137/newtons-magnets/dlattach/attach/171711/
   best wishes
            floor
ayeaye
Quote from: Floor on December 09, 2019, 04:31:36 PM
I suspect that what you and Citfta show, is just an ordinary shielding. Magnets made of iron certainly also work as shields. Other magnets, depends on what exactly are they made of, even ceramic magnets can work as shields. If so, all this intricate interaction of poles, etc, is just unnecessary. What it's basically about is just putting a shield between two magnets, certainly the magnet that repelled before, then will not, rather it attracts to the shield. And no overunity or anything in it.
This is of course my opinion. I thought how such experiments look like in the Coulomb model, and i found that in that model one magnet cannot shield another. And then i though, wait a minute, does it happen in these experiments either, or is it just an ordinary shield between two magnets. If you disagree, you should show that the shield magnet there doesn't work as an ordinary shield.
Analytical thinking.
kolbacict
The bottom is round, a magnet with four poles. From Capstan.From VCR.
https://youtu.be/puMoBd2cF10
banano magnets from the brush motor. What am I doing wrong?
Nothing happens...
ayeaye
Quote from: kolbacict on December 11, 2019, 08:56:30 AM
Nothing happens...
What are you trying to do? Your magnets are in some strong magnetic field, they stop in the neutral position, this is what supposed to happen. What do you expect?
You may get some better magnets. Can you get an old hard drive? You can get from there mu metal and a strong neodymium magnet. Neodymium magnets can also be cut, they are covered by chrome or whatever it is, but they are soft inside. What the result of such cutting is, i don't know though.
Floor
kolbacict  / ayeaye
Looks to me as if you guys have not a clue.
I'm guessing that you guys are what ... maybe 13 or 14 years old ?
Guess what .
"ideas" don't merit posting just because they popped into your head.
There needs to be,  some reasons / logic / knowledge base,  that gave them birth.
Those reasons should be presented along with the idea.
There should be good explanations given of both,  the idea and the reasoning,  that leads you think
that it will / might work.
       Such as
       what its supposed to do
       how it does this
       and
       why it works or could / should work
I have sat back and watched this for many weeks now, just to see if you
might have anything legitimate to contribute.   Both of you are batting less than a zero.
You're spitting out what amounts to gibberish...
Take it some where else.
Put up a topic of your own to post that crap on ?
                  floor
