Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
ayeaye
Quote from: lancaIV on March 08, 2020, 07:46:41 AM
https://en.wikipedia.org/wiki/Maxwell_stress_tensor
to https://en.wikipedia.org/wiki/Lorentz_force
This is all about the Maxwell equations, for magnetism these differ from the Coulomb model, and it thus may be possible that also Maxwell equations show overunity in some setup.
Again, this is not what i said, i said that when something is explainable by the Coulomb model, then the mere fact of that happening doesn't mean that there is any overunity, or any possibility of overunity.
Okay,but Coulomb model + Leon Foucault pendulum external influence ?
Pendulum variable  length( and thickness)  ~ two magnets variable distance ( and specific  material Gauss per volume)
Domain-sphere nano-distances effect !
Aligning from a permanent magnets compared aligning from an electromagnet with core or without ( air-core) !
MHD tube/channel to linear motor to "magic ring"( US Army,Leupold)
We are living in a Meta-material era ! Impossibilities making possible !
And Meta-effect on/off switch : a(b)-/normal  ! a(b)-/conventional
ayeaye
Quote from: lancaIV on March 08, 2020, 08:09:48 AM
I don't think there would be any noticeable effect, But even if energy can be obtained from the Earth's rotation, that is not yet overunity.
But everything that differs from the Coulomb model, yes there is a possibility. As my experiment also shows, that is now replicated.
Coulomb was eating dinner. But he found that eating alone doesn't give him enough satisfaction. So he decided to create a model. The model he created is since then known as the Coulomb model.
Royal Academie of Sciences,Paris/France : the members were often royal,part from the crown council ( Dukes,Earls,et cet.)
Beside Laplace,Ampere,Coulomb also an Biot and an Savart !
I mean you know about the academy decision related " ppm".
There has been a french thinker and "futurist",not-membered by this academy,whose claimed to have a water-motor concept,with an " impossible"- output result !
He got help by his final development of a real demontration-able prototype ,I do not know anymore by which : Biot or Savart  !?
There are virtual " ...... model"-s and there are physical "Think-Model"-Unikate/Prototypes !
And " Philologic House"- Haeretiker  !
Bon appetit  !
Salut
OCWL
p.s.: is there not a natural switch/spring-effect in action when you take a NS-Kompass/Bussola  ?
        How useable/transformable in/as pm-em motor  ?
       Heat pumps are now transformable to thermodynamic  cycle engines with PROCESS POWER OUTPUT ≥ 1
      But yes, it is an ambiental environment interchange and conversion process =      open cycle = steady flow converter
# 488 : Coulomb - scheme : with two springs ( Lord Kelvin !) altered ?
https://books.google.pt/books?id=pEYxDwAAQBAJ&pg=PT114&lpg=PT114&dq=lord+kelvin+spring&source=bl&ots=fNsDtOJn_0&sig=ACfU3U2C5U9n3TK76USjUKOEsbBO3U_jyw&hl=de&sa=X&ved=2ahUKEwi9vPinoovoAhURdBQKHTx5A1gQ6AEwBHoECAwQAQ#v=onepage&q=lord%20kelvin%20spring&f=false
             bimetalic !
             DE3047757 and DE3048277 usefull to incorporate  ? For laboratory experiments  = "model"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820715&CC=DE&NR=3048277A1&KC=A1
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820715&CC=DE&NR=3047757A1&KC=A1
Internal cw or ccw angle velocity/ angle momentum versus external cw or ccw angle velocity/momentum :
           a-/ synchron  = syntonization = in Resonanz-Stadium erbringen,Risc : Resonanz-Catastrophe
         ~ " gold melts in roomtemperature" Selbst-Zertruemmerung/material-volume-implosion
Floor
The TD interactions when......
1. SL (sliding) is limited to from 0 to 22 deg. SL indicator scale.
2. RO  is limited to from 0 deg RO scale (a right angle to SL) to 30 deg
(off from Right angle).    Note SL is repelled from RO at 30 deg. RO.
cycle is
1. RO is at 30 deg. RO scale    while     SL is at 22 deg. SL scale.
2. weight is applied to SL pulley string in decreasing increments of weight.
3. simultaneously, 135 grams is lifted on the RO weight Pulley, from 30 to 0 deg.
RO scale.
4. RO and the 135 grams are latched at 0 deg. RO (right angle to SL.
5. SL is pulled back to 22 deg. SL while RO  remains at 0 deg. RO.
6. RO weight object falls 30 deg. RO. while SL remains at 22 deg. (SL scale).
This returns the RO  magnet to 30 deg (RO  scale).
yield around 40 % more work out than in.
               floor
