-Smudge's Musings * A magnetic battery consideration with a simple experiment
Started by ramset, November 10, 2016, 06:57:46 AM
ramset
Cyril has proposed a simple "possibility" for consideration ?
regarding Image below
[Smudge/Cyril]
here is a suggestion for an experiment with a fabricated array of triangular flux concentrators cut from sheet, interconnected with copper wires.  The whole lot placed between two slab magnets (not shown).  This could produce measurable DC voltage or current.
end quote
All comments / questions welcome
respectfully
Chet K
Thanks Grandma
e2matrix
I can't see any power being generated without movement of the magnets.   Thank about iron filings placed around a magnet.  They don't move so with a static field why would this create any current?
ramset
Below is the "magnetic battery considerations" PDF
it is in the first post but for some reason at the top of the image and I see people have not been aware
so here is the explanation [below PDF]
thank you for looking, all comments welcome.
respectfully
Chet K
Thanks Grandma
tak22
ramset
I will see if a small discussion on recommended materials , dimensions ,etc can be started here.
Cyril has limited time to interact  but will be helpful whenever possible ! [as will others I am sure]
Good to see you around tak
respectfully
Chet K
Thanks Grandma
