Help fund our research into propellantless propulsion
Started by Quantum_Spider, November 10, 2016, 12:56:46 PM
Quantum_Spider
Quantum Dynamics Enterprises, Inc is proud to present C.I.D. centrifugal impulse drive. Patent pending.
A new replacement for the ion drive and hall thruster.
In this video we will prove propulsion.
torsion balance
torsion balance, instrument used to measure small forces. It is based on the principle that a wire or thread resists twisting with a force that is proportional to the stress. The torsion balance consists essentially of a wire or thread attached at one end and arranged in such a way that a force applied at the other, or free, end tends to twist it out of shape. The force is measured by the extent to which the wire or thread is so twisted. Torsion balances are used to measure small electric, magnetic, and gravitational forces. One type is used to measure small weights. The invention of the torsion balance is commonly credited to the English geologist John Michell, who made his instrument c.1750, and to the French physicist Charles A. de Coulomb, who independently devised such a balance c.1777.
HOW CID WORKS: https://en.wikipedia.org/wiki/Parallel_axis_theorem
All videos:
Proving propellantless propulsion.
https://www.youtube.com/watch?v=OnP5WnSzlbI
Video at 3x normal speed.
https://www.youtube.com/watch?v=SlH5yiuuu7Y
Reverse Thrust.
https://www.youtube.com/watch?v=3Ve7xkFhoKI
Complete powerpoint video.
https://www.youtube.com/watch?v=li67qzfsBaM
Torsion balance Test.
https://www.youtube.com/watch?v=HN785Un_ykc
Taped rotor.
https://www.youtube.com/watch?v=DfC8P4z3MMs
Closeup of magnet orbit.
https://www.youtube.com/watch?v=Z4ny9ng4wXU
Wrapped in cellophane test.
https://www.youtube.com/watch?v=2fXH_ioogpQ
No magnets on rotor.
https://www.youtube.com/watch?v=fA3zniDUMrI
Sincerely,
Harry Sprain
Pres. CTO Quantum dynamics Enterprises Inc.
https://www.facebook.com/qdeinc/
https://igg.me/at/QDE/x/15580283
mscoffman
To test an ESD indisputably one would like to place this engine at the center of a superconducting lead baggett such as was done for critical
electromechanical components of the Einstein Gravity Probe B spacecraft. A real neat way of powering it would be to use a fiber optic cable at a
power of 1Kw optical to high efficiency photocells inside. A superconducting lead walled container cancels out all magnetic fields.  The only problem
with this is one would need to remove all the heat being generated, as the electrical energy is being used for the drive. One of those 80% efficient
magnetrons such as used in the ITER fusion reactor would help.
If you think about it an ESD within a superconducting lead container would be the unquestionable way to test the ESD drive as any magnetic field would
be able enter penetrate into the engine cavity normally. The ESD drive then would unquestionably have to convert upgraded energy into inertial momentum
if it is to produce any trust.
