Help fund our research into propellantless propulsion
Started by Quantum_Spider, November 10, 2016, 12:56:46 PM
sm0ky2
This concept is so simple, it didn't take long to prove it works.
It's actually quite a novel breakthrough in inertial propulsion technology.
Not sure that there's too many billionaires on this website that could help you
Launch stuff into outer space, but best of luck to you.
Mind if I 'borrow' this to play around with propeller-less watercraft?
lumen
The real reason it works is because the compressed magnetic field is released and expands as the magnet moves outward forming a local flucuation or polarization in space time causing the magnet and slide to have slightly less apparent mass. Then after space time is normalized the magnet is pushed back in by the frame magnets collapsing the magnetic field causing space time to compress as the magnet and slide are pushed back into position at a slightly larger apparent mass causing the device to slightly shift position on each cycle.
MT
Quote from: Quantum_Spider on November 16, 2016, 09:31:40 AM
The reason CID works.
https://en.wikipedia.org/wiki/Parallel_axis_theorem
Hi,
thank you for posting idea here. I like it. Videos provided are sufficiently proving concept to me that it will work on earth. But will it also in space? in zero gravity environment? In one of videos was planned to use second rotor-stator combination but I think this will compensate only for stator rotation in zeroG. There are also other actions like magnet going outwards which is then pushed inwards by stator. It is dificult to see what would be resulting force vector. On earth is stator kept stable by gravity but in space it is just an object with certain mass folowing third newton law: every action has equal but opposite reaction.
anyway I'll consider a small donation,
Marcel
Quantum_Spider
The torsion balance simulates zero gravity. So the device sitting there as a begins to move if you watch it carefully it goes backwards and then forward and backward just a little bit and then forward more and the back and forth back and forth and he keeps doing that but one motion is stronger than the other and that begins to build inertia and the device starts to accelerate and makes about three revolutions. Until the tension in the string becomes so great it can no longer rotate. But it doesn't just unwind it will sit there as long as you keep it turned on only when you turn it off will it unwind.
Thank you,
Harry
Quantum_Spider
Quote from: lumen on November 16, 2016, 11:55:38 PM
Very nice I like it.
Harry
