Why Over-Unity is Possible
Started by pauldude000, November 16, 2016, 09:39:04 PM
synchro1
The heat from the electromagnet coil is feeding the permanent magnets the thermal heating to offset the cooling effect of the magno-restrictive MCE of the pulse.
The electro magnet has a steel case between coil and ceramic magnets.
seychelles
JUST LIKE TO REMIND YOU ALL THESE ARE OFF THE SELF ITEMS THAT CAN BE PURCHASE ANYWHERE IN THIS
WORLD.. THE FINAL OT WATER TO STEAM WATER CAVITY HEATER CAN BE REPLACED BY A MORE EFFICIENT
INDUCTION WATER TO STEAM INDUSTRIALIZE SYSTEM..
https://www.google.com/search?q=charles+law&ie=utf-8&oe=utf-8&client=firefox-b
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1#
"Photon( light) Phonon(wave) " absorber : black (w)hole principle
            vertere/tornar/winden/drehen:            "(w)hole"/Ampere-turn
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FDynamoelektrisches_Prinzip
Mental designing :
http://www.arminwitt.de/hoegl.html
Steel + silicon https://www.cam.ac.uk/research/news/solar-grade-silicon-at-low-cost solar grade 8 US$/Kg
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.arminwitt.de%2Fhoegl.html
Next step would be similar low cost : https://en.m.wikipedia.org/wiki/Black_silicon
                                20-30% conversion efficiency of incident light :
                                                              parabol foil
https://www.google.com/search?q=parabolic+solar+concentrator&tbm=isch&source=univ&client=firefox-b&sa=X&ved=0ahUKEwjkkNa_oKfhAhUwx4UKHeQ0Dd0QsAQIIA
                   Light concentrating factor ?" Coil cell "un-/ cooled,  in tube evacuated  ?!
                                                              As example :
http://www.ecochunk.com/6361/2013/02/22/cool-earth-solar-develops-inflatable-solar-concentrators-to-boost-energy-production/ ".... up to 1200 times more electricity ..... "
         From natural - periodically - light/ photon-phonon source to permanent 24/365 conversion process :
                                                        "Artificial fusion chamber "
             https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#
                                                            And related :
              http://www.lenr-coldfusion.com/2013/03/14/lenr-cfl-light-bulbs/
                        There is much research about radiant emission converting material :
https://www.google.com/search?q=carbon+instead+silicon+solar+cell&ie=utf-8&oe=utf-8&client=firefox-b
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=ES&NR=2265253A1&KC=A1#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=29&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941208&CC=DE&NR=4318270A1&KC=A1#
                                      Compact micro device production
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=20040916&CC=US&NR=2004178874A1&KC=A1#
                                          The " numbers" curiousity and treat
A.
             https://tesla3.com/wp-content/uploads/2016/11/zpe_hilden_brand_valve.gif
                                    double the flux lines four times the force
     Question :                 only attractive or also repulsive ( internal/external field force )
B.                                               magnetic force to rotation
             Richard Fradella generator RPM/ output ratio description
                                          ( like all other conventional generators performance)
            rated and nominal 1000 RPM : 1000 W              1,00 W/ round
                                                500 RPM :    125 W.            0,25 W/ round
                                                100 RPM  :        1 W.  =       0,01 W/ round
                                   Measured efficiency in all three cases : around 95%
Several different ratio results to conclude ! By the same - only - " force converting machine"
This is important to understand the over-sized or under-sized use and performance of generators and/ or motors !                                              charge/ load : ideal resonance point
And to remark the great power saving potential if change from fix ( net frequency controlled) speed/ load to variable and controlled speed/load charge and pulse-2-magnetic force-2-pulse recharge circuit ( feedback cycle)
            And to transform this physical rotative process to MEG-calculation as "static dynamo".
C.                     Force-" F= BIL" balance for counterforce ( BEMF/FEMF) neutralization
                          MMF/EMF ? permanent or periodically/ pulsative
               remark Hildenbrands number about "4 times force units amplification"
               8 Watt permant DC for electromagnetic force/ 1 inch permanent neo magnet force aequivalence
               = 8 W permanent DC/ 3 ( surplus) units ~ 2,6 W permanent DC per mmf unit
               working with pulsed DC  pulse: current on/ off cycles + feedback cycle
             Motor disc rotor : 360° cycle , 2 poles with 10° attraction/repulsion space : 10° /360° = 1/36 power on                                             and 35/36 power off
                                             rated 360 W = pole field Watt consume = periodic energy need = 360 W/36
D.  " free energy home plant" study and error/ success controls for best performance :        in household the " consume Wattpeak centre" : the kitchen
       The greatest task to resolve :       https://en.m.wikipedia.org/wiki/File:Inrush_current.gif
                                             http://rakarskiy.narod.ru/_si/0/19966480.jpg
                                               To controle and regulate :
                 https://www.ametherm.com/inrush-current/inverter-inrush-current-protection
                 V-Ampere-max. peak and V-Ampere- average peak and duration !
                                      Out from inverter : up 3 KWh power per day                                      + solar collector heat
                 https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.oeko-energie.de%2Fprodukte%2Fsolarstrom-photovoltaik%2Finselanlagen%2Findex.php
                                                       https://mtbest.net/
                                                             sommer/ warm season
                  3 KWh = 3000 Wh / 24 hours = 125 Watt generator output need /0,5( losts charger,  battery,  cable)
                                                    sufficient by battery-storage :
                                                    250 Watt nonstop  generator
                                                   5000 Watt-hour batteryset
                               Better : partial  " on demand" load charge delivery by generator
                                            and lower capacity battery-set ( DoD- malus)
                                                  500 Wp nonstop generator
                                                3000 W-hour batteryset
   Actually there is price related a scientifical competition between battery and hydrogen technology
             so probably instead batteryset hydrogen-genset
  Or the development from a 1 KW by load demand controled mo-gen rorative/ mo-gen static makes the batterysetand hydrogen-genset obsolete.
Rare,  double sided motor shaft,  but existent. !
https://www.google.com/search?q=double+side+motor+shaft&ie=utf-8&oe=utf-8&client=firefox-b
"Relative speed accelerator ":
a generator with rotative rotor and fixed stator to rotative stator : outer and inner rotor : one cw and the other ccw
the rotative generator stator combine/ couple  with one motor-shaft side and the rotative generator rotor combine/ couple with the other motor shaft side
Only with this combination we get a transformer ( con-/inverter)  equivalent rotative circuit cycle. !
