TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
gotoluc
The below are input and output charts
Luc
woopy
Yep Luc
Fantastic work
If i understand well, the measurement begins after the stroke ends,  when the  the rotor and slider are at full stop.
I enclose a rotating drawing made on your graph, so correct me if i am wrong
Seems that  i have to order some magnets and sliding bearings  tomorrow he he !!  :)
Thank's so much for sharing
Laurent
gotoluc
Bonjour Laurent
It's always a pleasure having you participate
Your understanding of the test device and timing drawings are perfect. Thank you for posting it.
Looking forward to your build and test results
Kind regards
Luc
woopy
Hi webby and Luc
Just received my ferrites magnets this morning.
To Luc
I am planning a setup and i rewatched your  video on the V2 device for details. It seems that you say that the rotor diameter is 22 inches so the outer rotor distance is 22 x 3.1416 = about 69 inches, so half distance (180 degrees)  is 69 / 2 = about 34.5 inches. So i don't see where the 16.125 inches (in your last calculation for 180 degrees ) are coming from ? Have you installed a second rotor for the measurement or i am missing something ?
To Webby
Thank's for input
Sorry if you have already done it, but may i ask you to explain how you get the Joules datas from the colum " gram pull"
Laurent
gotoluc
Quote from: woopy on March 21, 2017, 12:23:33 PM
Hi webby and Luc
To Luc
To Webby
Thank's for input
Laurent
Oh no Laurent, I now see a terrible error!... the 16.125 inches was for each section of disengage then engage. So the 16.125 inches would have to be multiply by 2 = 32.25 inches of outer rotor traveled for 180 degrees, making the rotor 20.53 inches in diameter and the device under unity from the calculated math.
So the input rotor traveled 6.45 times the distance of the output. So input average is 1.1Kg x 6.45 = 7.1Kg input to 6.25Kg of output so under unity by about 12%
I'm so sorry for your trouble and expenses.
Please accept my apology.
At everyone, please accept my apology for the trouble my over site may of caused
Kind regards
Luc
