TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
lota
Hello
If you modified this a bit it could go. I'll print a model. For this arrangement.
greeting
"Magnet shear to direct pull work ratio" (overunity.com)
Lota
Floor
Hello Lota
Keep in mind.
1. The shapes of the magnets used have effects upon
these types of interactions.
2. Magnets of the same physical dimensions sometimes have
more variation in their field strengths  than one might expect.
This has given me troubles on more than one occasion.
3. There are forces present in undesirable directions.  I recommend to
any one, that they should become familiar with those other force vector potentials
first, in order to build so as to compensate / withstand them.
4. I  recommend starting a topic for presenting your build, when you are ready.
best wishes
       floor
lota
Hello
I already had a model with a crankshaft. It looked quite good. The force must be stored between and several magnets offset arranged.
I designed this with SAM Simulator. This allows you to simulate curves and gearboxes.
greeting
Lota
https://nolte-nc-kurventechnik.homepage.t-online.de/rechen_koppelgetriebe2.gif
Floor
1. Did you see my last post ?
2. I'm working on and presenting an other design here
at this topic.
3. Do you understand this ?
4. The design given in your GIF animation is not quite there /
not quite the right lines of motion.
5. I will give my feed back in another topic if you wish /  if you start one.
  best wishes
         floor
Floor
I'm going to request to lock this topic
               but
continue it in a different thread
                As
   "modified gotoluc design "
https://overunity.com/18866/modified-gotoluc-design/msg557639/#msg557639
    best wishes
              floor
