TD replications
0 Members and 34 Guests are viewing this topic.
gotoluc
Quote from: Cairun on February 22, 2017, 01:05:40 PM
Upon playing more with the ceramic magnets, I realized that continuous rotation may not be achievable with your setup.
The output magnet seems to only do positive work in the 11 mm stroke(maybe a tiny bit more than 11mm), and as it moves further than 11mm it enters into attraction mode which essentially creates a sticky spot.  Unless I am setting up my magnets in the wrong way.  Can you confirm this or let me know what I may be doing wrong?
Alex
Hi Alex,
It is difficult to see what's different without seeing what you've built. Can you make a video so I can see what could be different.
Two things my device has is, the magnets on the wheel are alternating north south and the 11mm magnet has stops (wood blocks) to limit the 11mm magnet stroke so it does not get out of range.
Maybe watch the video again to see these limiter blocks.
Looking forward to seeing what you've built.
Luc
Cairun
Luc,
Thanks for the quick reply.  I did notice the alternating magnet pole arrangement (which is where the self re-set comes from), and the limiter blocks (which is where the 11 mm is coming from).  I am trying to emulate your setup exactly.  I guess my question is if you remove the limiter blocks, how much further will the slider magnet travel beyond the 11mm distance.  Apparently, don't remove the limiter blocks just to answer my question.  I will set something up tonight and make a video to clarify my question.
Alex
gotoluc
The 11mm magnet can travel a little more then where I limited them but if its center goes past the side edge of the rotating magnet it won't flip back on its own when the next rotating magnet comes in. That's the main reason for the limiters.
Luc
Floor
Opening a latch while it is is under a large force
can use a lot of energy.
gotoluc
I stumbled on this video and wondered if anyone has heard about this device.
MTG (Magnetic Torque Generator)
Link to video: https://www.youtube.com/watch?v=NI2Fwb91PhI
As for my device, I should have a larger version to demonstrate late next week.
Luc
