Earth Energy Batteries
Started by FreeEnergy, April 20, 2005, 08:31:00 PM
Pirate88179
Robbo:
Thank you for your kind words.  Just remember, I am not inventing anything here, I am just replicating and combining others previous work.
I have not made a tutorial on the modified Fuji circuit but, that is an excellent idea for a video.  I have not figured out how to add still photos in my videos but I am sure my software can do it.  That way, during the video, I can insert good close-up shots of the circuit board.  It is really easy.  I don't know all that much about electronics really, I am still learning here but, when I made my Fuji circuits, I knew even less.  If you know how to solder, which is not hard, you will be set.
There are 2 different Fuji boards out there and I have only had success with the AA board. (they also make an AAA board)  But, Jeanna in our group, found out how to tell which type is which by the outside of the camera so you can tell before you buy one.  I will dig out all of that info and hopefully make this video soon.
Very good idea and I thank you for it.
robbosdog
Its a pleasure Bill , I have some research on earth batteries as well , I was into it a few years back when I lived out of town and had the room , I'm in the city now and have to settle for cells ;) , I did have a go at hooking an Ariel to one , the next day there was melted stuff everywhere so I take it that it works , it was over winter and I can't say it didn't get hit by lightning but.........
A friend's dad gave me some what looked like cheese cloth with a waxy finish , he said it was all the rage back when ppl built their own radios and stuff  , but I have never seen any for sale , its what I used for the insulation , I saw a motor cycle that required a battery to run start while connected to it , it was funny as the guy with the bike said I was mad for believing in  such rot  ;) the look on his face is burned in ( all ways gives me a laugh ).
A point I wish to make to fellow members is that the oxide created on decomposition of the zinc is reclaimable , the best way I know of catching  this is to wrap the zinc in moist felt ( think billiard table) it will last for years buried and holds any oxide that may build up. The felt also dose something with the way the ground “touches “ the zinc more contact area or something like that .
Formula : add a small quantity of carbon powder to the  zinc oxide heat to 450 â€" 600 c â€" bingo!!!  carbon dioxide and pure zinc , done in a solar oven to so it’s a clean process.
Something I was told but never tried was to use water in a rubber tube to join the rods in stead of wire  , the guy that told me this had a roll of it , really flexible not like the small hoses on cars more like something medical , I will try and get the name of it .
Robbo.
robbosdog
HI Bill Have can you put a switch before the pos wire goes to the coil and quickly turned it off and on ?  to see if the voltage out of the coil increases any disenable manner  , I’m thinking a crystal radio and  its antenna here
To quote from Wicka ( that great source of truth ;))
“ The long wire type antennas often used with crystal radios are Monopole
antennas. To receive signals from this type of antenna, a ground reference is
needed to provide a place for the antenna signal electricity to flow into and
out of. Because crystal radios have no other source of power than the electrical
power they receive from the antenna, the grounds for crystal radios must be much
better than those used by amplified radios.
http://en.wikipedia.org/wiki/Crystal_radio#Attempts_at_recovering_RF_carrier_pow
And ,
The antenna
"A monopole antenna is a type of radio antenna formed by replacing one half of a
dipole antenna with a ground plane at right-angles to the remaining half. If the
ground plane is large enough, the monopole behaves exactly like a dipole, as if
its reflection in the ground plane formed the missing half of the dipole"
http://en.wikipedia.org/wiki/Monopole_antenna
has anyone tried using half of an electric motor ( every second winding ) with
the above connected to the rest ? , sort of like that John Bedeni fan thiggie
that charges batteries and keeps you cool for nix , was just wondering if this
would be a way of doing it , they used a 100 foot or something like that of
arieal and seem to have been able to know what they would get from it .
So one long vertical wire in the air and another buried at the ¼ wave length
blah blab blah , and as the power is coming from the ether anyway and its in
Wicka we are not breaking any thermo dynamic laws laws , or twisting any noses ;)
Doesn't this ether power recover/recharge as quick as you can flick the circuits , to quote again :  " Although crystal radios are designed to detect AM, they also frequently detect FM fairly well which is in the 100 MHz range."  hmmm ?
seems that way with a crystal radio.
the faster you flick that switch  the more you get ?
And could post a link to a quick schematic of how you are doing an earth cell just want to see if you are doing as we were .
Robbo
jeanna
Hi robbo,
I don't know about the rest of it, but yes,
when you flick the switch you will get more.
In a changing magnetic field the electricity flows through a wire.
If the changing magnetic field changes faster, you get more.
If the magnet crosses the wire more times (a coil) it gives more.
what else?
There are more things, but those 2 are what I am using all the time in my work with the joule thief and earth battery experiments.
thank you,
jeanna
Justalabrat
Youtuber oglundasotarn has a "Dirt Battery" connected to a joule thief driving 3 white LEDs.
;D
http://tinyurl.com/nxp2er
