Bozidar Lisac
Started by antimony, December 16, 2016, 09:17:54 AM
antimony
Hi, I printed out a few pages of Patrick Kellys chapter 5, because i have trouble reading on a screen.
Anyway I printed out the patent documentation of a guy called Bozidar Lisac, which i found interesting.
I don't know if you have heard about this guy, but I just wanted to ask if there was someone who had.
I googled, and i didn't find anything from this forum or any other.
Patent application nr: US20080030165
Low-Q
I'm a little confused where the inventor is heading with this, but I think he is wrong about the work from the capacitors.
When in parallell, the capacitors C will be charged with the same voltage within time T. The capacitance is 2xC at a given voltage 1xV, and the charging time is 2xT.
When the switches turns the capacitors into series, the total voltage V is 2xV, but the total capacitance C is C/2. So the discharge time is reduced to T/2, enabelig the capacitors to discharge fully and not partially.
Vidar
antimony
As I understand it is not a "real" patent, but an patent application so it may not be anything. If
But has anyone any experience with these circuits or if anything it would be easy to throw them together.  I am going to give it a try but I am new to electronics as you may know if you have already read some of my earlier posts. :)
citfta
That patent application is simply a cheap attempt to copy someone else's work and profit from it.  The idea of recycling the energy by charging and discharging caps goes back to 1989 when Ray Nelson demonstrated his scalar battery charger to John Bedini.  The idea has evolved for those of us working on it into the Basic Free Energy Device found on the Energetic Forum and also found here in a thread called David Bowling's Continuous Charging Device.  Here is a link to a thread discussing the original device:
http://www.energyscienceforum.com/showthread.php?t=70
I hope this helps to clear up some of the confusion.
