All Magnet Motor TD based
Started by Floor, January 10, 2017, 08:41:31 PM
Floor
New circular notes
Lenz law
not just magnetic attraction and magnetic repulsion balancing  during the rotation.
the magnitude of an induced voltage is (in part), dependent upon a magnetic fields speed of motion,
                          and / or
a fields speed of expansion or collapse while passing through a conductor, is it not ?
inductive "kick back" of one coil, fed to the start up inductance of the other coil ?
but are the voltage PEAKS in sink or are they 180 out ? or what ?
one field through a coil needs to be collapsing, while another field though an other coil  is expanding ?
                                                             OR ?
not just series electric polarity, but a COLLAPSING magnetic field, induced electric voltage polarity, connected in series (+ to -), to (an EXPANDING ?) magnetic field, induced electric voltage polarity ?
                                              OR SHOULD IT BE
not just series electric polarity, but a COLLAPSING magnetic field, induced electric voltage polarity, connected in series (+ to -), to (a COLLAPSING ?) magnetic field, induced electric voltage polarity ?
inductive kick back of one coil, fed to the start up inductance of the other coil ?
should not, the voltages PEAKS (ALTHOUGH STILL + TO -) of those two coils,
be made to be in sink ? and not 180 out (as are the voltage polarities) or what ?
Note ....  there is no sudden disconnect of the electric currents generated in these rotating designs
nor an abrupt break away of the magnetic fields from the coils.  No extremely rapid collapse
of the magnetic field, for example... as there would be during a complete disconnect of a
power supply from a coil that it was supplying.
can there be a neutralization of Lenz actions by the creation of a balance between Lenz
actions ?
   just pondering .....  NOT LOOKING FOR "PAT ANSWERS" unless, you personally, have
already demonstrated a way to make further advantage of the Frodrik Lenz law.  Just pondering.
Please look at these magnet set interactions attached below as "Force balancing demo"
drawings /JPGs  numbers 1 through 4.
                     floor
Floor
Sorry, this last post was intended for a different topic.
         floor
