multiplying AC electricity by using varying sizes of pulleys
Started by that_prophet, January 13, 2017, 06:39:51 PM
that_prophet
Here is GEM = (Geometrical Electricity Multiplication) a simple free energy technology
for the Tribulation Saints = (which could be easily built, out of a large pulley with a DC drive motor + at least one mini-pulley attached to  an AC generator, to be used as a multiplier)
http://free-energy.yolasite.com/
((( NEWS of this ancient technology will change the world )))
I have the MOST IMPORTANT NEWS
To share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM=(Geometrical Electricity Multiplication) technology will eventually lead us to a way of defeating + repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor)
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only have to put one spark of DC electricity into this GEM=(Geometrical Electricity Multiplier) mechanism, to get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it. This GEM of a mechanism runs by converting the 10 X100 = 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor, by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology works by only having to put one spark of DC electricity in, which can return you 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity. These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) + torque is caused by producing power, which is P=AV, or Amps=current multiplied by Voltage + massive voltage times practically zero current, still equals practically zero torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering. http://beliefstoliveby.yolasite.com/
These AC generators would run freely, as torque is caused when you're producing power, and since P=IV, or power is equal to current=(I) times (V)oltage, there is practically no power being produced. I can say this, considering that the only current you need to drive your DC drive motor, is merely one spark, or practically zero, and zero times anything is still zero. For this reason, I believe that these AC generators would take practically zero torque to rotate.
This technology is in the Holy Bible = in Ezekiel 1:16 where he is describing what a UFO motor looks like while it's running so this technology will eventually lead us to anti-gravity as well as not only speeds approaching the speed of light but also the ability to do 1000 kph vectoring
I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. He was worried about the rumors that anyone who actually built a working free energy mechanism was soon after found dead. So, because he feared for his life, as well as the lives of his family, he asked me to not give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
SkyWatcher123
Hi all, Hi that_prophet, I am aware of the controversy about the idea you are sharing, though i am planning on building a stationary human powered bicycle generator for a fun project and exercise.
It will use either friction wheel at tire or a belt around the wheel rim, haven't decided which design to use yet.
It sure seems like a similar concept to your idea.
Would this bicycle generator idea be similar in function to what you are teaching?
If it is similar, then could it be possible, that these simple stationary bicycle generators are already proving the principle and people are not even realizing it.
Meaning, they are getting much more power into a charging battery, than what it would normally require, due to the fact they are using the large pulley design and the small pulleys on the generator.
peace love light
that_prophet
YES,,,,
this would be the same principal
you only have to input the DC electricity to rotate your large bicycle wheel once, (1 meter circumference)
which with a DC motor is only one spark of current, (to rotate it one full time)
+ then you get to have an output of 1000 cycles of AC electricity, (or the circumference of a bicycle wheel)
for every 1 millimeter circumference mini-pulley that you attach to the system,
and attach an AC generator to, (you would get 1000 cycles of AC electricity)
if you chose 10 mini-pulleys, you would get 10,000 units of AC electricity,,,,,,,,,,,,,,
HOW COULD YOU GO WRONG
this is so simple, that it is ridiculous that we have not figured this out earlier
(this is proof that there MUST be an evil force that is desperately trying to hide this tech from us)
Remember, these mini-pulleys with AC generators attached take practically zero torque to rotate,
as they only need to produce one spark of DC current as output, (after running your AC output though a full wave bridge rectifier)
+ torque is caused by generating power, which is P=IV, and no matter how much (V)oltage you wind up,
it is still multiplied by practically zero current-(I), (you only need to generate one spark) to keep this running
THANK YOU SkyWatcher123
Quote from: SkyWatcher123 on January 13, 2017, 11:08:49 PM
peace love light
SkyWatcher123
Hi all, Hi that_prophet, ok thanks for the reply, so we shall see how it works once i'm done building it.
I can always connect a dc motor to the pedal sprocket or even the rear free wheel by a chain, then some tests can be made that way also.
This is the design i will be emulating, shown in this pic.
peace love light
