GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
Dog-One
Quote from: Paul-R on March 06, 2017, 11:06:25 AM
The trouble with people like that_prophet is that they pull down the reputation of this site.
In general, there are quite a few people who cannot explain their way of thinking.
If they could and attempted to walk through their idea, step by step, most would
realize their mistake.
It's a rare breed that can accurately communicate an idea with no missed steps
or overlooked calculations.  In almost all cases they are able to do this because
they know the material inside and out, they've done the benchwork; they don't
need to read from a script.  It's almost a shame we don't enforce some kind of
protocol here at this forum to ensure what is posted has actually been clearly
thought through.  It would save us all a lot of headaches.  There wouldn't be
threads with 1500 posts.  After about 50 posts, there would be either a solid
concept and possibly a solution or it would be a dead idea, case closed.
that_prophet
This is based on the simple logic of it not costing 100 times as much energy to rotate a 100 cm circumference pulley as it does to rotate a one centimeter circumference pulley.  Yet when you run the 100 cm of belt off of the one rotation of the large pulley, past 10 mini-pulleys of one centimeter circumference, we can multiply the amount of rotations by 100 for each mini-pulley, and if you added 10 mini-pulleys, then you would multiply the total # of rotations by 1000, and by adding AC generators to these 10 mini-pulleys, we can multiply AC electricity.
   These 10 mini-pulleys run very easily, as they are only winding up massive voltage, needing only to generate the small amount of current to rotate the drive motor one single time. The massive amount of voltage is used to crank the large pulley over once, which would make this a self generating mechanism. This works by only having many small pulleys rotating freely, as they are only generating massive voltage, with extremely small amounts of current being needed to generate the large drive motor only one single time.
   So you would get 1000 cycles of AC electricity, to produce only one spark worth of current, the amount needed to power your large pulley for one revolution.
Dog-One
Joe,
You're not seeing the obvious.
With a generator having a large pulley, it is easy to turn it.
A motor with a small pulley makes it easy for the motor to turn a load.
Your setup is ass-backwards.  You have the motor connected to the
100cm wheel which means the slightest resistance on that wheel will
make the motor impossible to turn.  Then to make matters worse you
have ten generators with small pulleys; again if these generators have
the slightest load on them you have no leverage, no torque to turn them.
Even if the generators have zero load, the bearing resistance will be
enough to where the large wheel skids instead of turns them.
What you are stating is attempting to use mechanical advantage completely
backwards.  Instead, at every point you are creating a mechanical disadvantage.
I don't even have to get into the electrical side of your GEM, I can see
mechanically you have everything flip-flopped.
Now, if you were to reverse everything and use ten tiny little high speed
motors with small pulleys and one large low speed generator connected
to the 100cm wheel, you might actually have something worth experimenting
with.  It would all depend upon how efficient those motors and the generator
is.  I highly doubt you would be able to achieve self running, but at least
you would be fully utilizing mechanical advantage.
Just a side note, there are some motors out there that can reach incredibly
high RPMs and if the load is nearly non-existent, they consume almost
no power in those conditions.  Ten of those motors might be able to turn
a wheel and provide enough torque to actually get a generator to produce
a little power without the motors loading up and slowing way down.  If the
motors are all low voltage and connected in series...  Who knows.  Might
work.
Paul-R
Quote from: Dog-One on March 06, 2017, 03:03:48 PM
Yes, but that's not what we have here. The man has been told a hundred times and perseveres unchanged with his rubbish.
In reality, I wonder if he cares,. This thread and the two dozen others that he he created are merely a vehicle to publish his daft religious ideas. He has abused his privleges and Stefan should Yellow Card him for the sake of the site.
pomodoro
Have you tried energetic forum phat profet?  You may get more belief over there. I believe there is a priest of two floating around over there.
