GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
Paul-R
that_prophet
http://free-energy.yolasite.com/ this is so simple that it should be obvious,,, you only pay one spark of DC current to rotate a 100 cm circumference pulley once, and through simple pulley mechanics, with 10 X 1 cm circumference pulleys with AC generators attached, you can easily gain 1000 cycles of AC electricity. These AC generators take practically no torque to rotate as they are only winding up massive voltage, with no need to gain any current, except for the one spark of current that it takes to crank over your DC drive motor once. Then these 1000 cycles of AC electricity easily have enough voltage to crank over your DC motor the one single time it needs to have this a self powering system. Of course you have to add 10 full wave bridge rectifiers, (4 diodes) to convert your AC output into the DC input that you need to power your DC drive motor.
PLEASE,,, DON'T LET EVIL FORCES HIDE THIS SIMPLE FREE ENERGY TECHNOLOGY ANY LONGER
I received this from God, after asking for a way to help the Tribulation Saints survive the soon coming Great Tribulation. http://doorschristmustpassthrough.yolasite.com/ I was first shown a 10 speed bicycle going uphill in 10th gear, and then back down in first gear. Then I later thought that it might have been an evil spirit leading me in the wrong direction, so I ask my Father to show me it was from Him, and not just evil spirits leading me astray. He Graciously pointed me to Ezekiel 1:16, where Ezekiel was trying to describe how a running UFO motor worked, "wheel in the middle of a wheel", or as I saw it, wheels inside of wheels. Since I did not have any thread technology where I could put wheels inside of wheels, I went with pulleys and a belt.
that_prophet
TIME IS VERY SHORT, AS WE ARE NOT ONLY LIVING IN THE END TIMES,
BUT ALL WHO ARE BORN AGAIN + LOOKING FOR HIS RETURN
= HAVE LESS THAN TWO YEARS TO LIVE,
BEFORE THE DOOR CLOSES ON THE BLESSED HOPE OCCURING
+ MILLIONS VANISH OFF EARTH.
Why I believe that ISRAEL'S 7 YEAR PEACE TREATY must start,
BEFORE JAN 15, 2019 when = http://2020-vision.yolasite.com/ =  1st DOOR closes
Of which, the second half of this duration, is known as the "Great Tribulation"
When Satan + most all of the fallen angels + their offspring = (aliens + giants)
Will be sent to this earth, "woe to ,,, earth and of the sea!" (Rev 12:12)
Remember that although we are warned "that day and hour knoweth no man" (Mat 24:36)
We are allowed to "know that it is near, even at the doors" (Mat 24:33)
Because we are "this generation shall not pass" = (Mat 24:34)
PLEASE ALERT THE WORLD ABOUT THIS HIDDEN TECH
((( NEWS of this ancient technology will change the world)))
Simplicity of using pulleys to multiply # of rotations, + by simply adding AC generators, we can actually multiply our AC electricity. It is truly that simple, and the only reason that we have not discovered this dirt simple pre-school technology before this, is the massive amount of spiritual warfare that is going on in order to hide it. Yes, Satan is teaming up with all of the evil spirits, to desperately hide this pre-school simple technology, and they have been able to cover it up for the most part, at least since the time of Ezekiel's writing in Ezekiel 1:16.
This uses the 100 cm of moving belt that comes off of one single rotation of a large 100 cm circumference pulley, that only costs a mere spark of current, the minute amount of electricity that a DC motor takes to rotate one full rotation. This moving belt is then run past 10 small pulleys of 1 cm circumference, to multiply your total # of rotations, and by simply adding AC generators to these small pulleys, we can multiply the amount of AC electricity. Yes, by adding multiple small 1 cm circumference pulleys to the same belt as the large 100 cm circumference pulley, we can multiply the # of rotations, and by adding AC generators, we can actually multiply the amount of AC electricity.
On one half of this system we are using the 100 cm of moving belt, off the single rotation of a 100 cm circumference pulley to wind up massive voltage, by multiplying the # of rotations of free running AC generators on 10 small-1 cm circumference pulleys, 10X100=1000. Then, on the other side of this, we are using the high amount of voltage, (electrical preasure) to rotate the large 100 cm pulley one single time.
These many small pulleys run free of most any torque, because they are only winding up massive voltage, as they only need to generate the small bit of DC current, that is needed to rotate the DC motor one single time, (which is practically nothing). This DC motor has a large 100 cm circumference pulley, producing 100 cm of moving belt to work with. I can say this because torque is needed to generate power, and P=IV, which is, "P"ower is equal to "I"-current times "V"oltage. Since the current is practically zero, and practically zero times even massive voltage is still equal to practically zero power = which means practically zero torque.
This works on the simple principle of through pulley mechanics, being able to trade one revolution of a 100 cm circumference pulley for 100 rotations of a one centimeter circumference pulley. This can be very significant, when you are talking about AC electricity, which is created by rotations. So, the more rotations can mean more AC electricity. So, in effect, you are using pulleys to multiply your AC electricity. http://free-energy.yolasite.com/
Best GEM = (Geometric Electricity Multiplier) free energy technology
This starts by only inputting one spark of DC current into a DC motor, or you could give the large 100 cm pulley a quarter turn with your hand, either option should start this free energy technology of an AC electricity multiplier perpetually running. This extremely minimal amount of DC electricity, is all that is needed to rotate your DC motor one single time. This can be very significant when you have a 100 cm circumference pulley attached, creating 100 cm of moving belt. If you ran this length of moving belt past 10 mini-pulleys with 1 cm circumference pulleys attached, you could produce 1000 cycles of AC electricity, as 10 X 100 = 1000. (now, try + tell me that you cannot gain enough voltage from these 1000 cycles of AC electricity to crank over your DC motor one single time)
Re: GEM=(Geometrical Electricity Multiplication)
In (Mat 13:39) it says "the end of the WORLD"
Now hold on,,, our world is never going to end,
Proof= (Isaiah 45:17) + (Ephesians 3:21) = "world without end"
This is mistranslated + should say "end of the AGE"
as in, the age of Christianity, (before Born Again Christians are taken up in the clouds)
Or this WORLD SYSTEM ENDS,,,,,,,,,,,,
then using 51.6 as the duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)
Starting with 1967.44, (when Israel took Jerusalem)
As Jerusalem was needed, as it was part of the 70 X 7s
MATH : 1967.44 + 51.6 = 2019.04
adding (6.9solar) = the 7 Hebrew year for the Tribulation,
then as for the door=deadline for Christ setting His feet on earth,
we would get 2025.94 = 2019.04 + 6.9
This way, we are shown both of the doors,
So 2020,(2019.04) is the 1st DOOR,,,,, (Rapture, meet in the clouds)
Or should I say, one of the DOORs,
And 2026,(2025.94) is the other DOOR, (when Christ sets His Foot on the Mount of Olives)
With so little time left,
As of Jan 17th of 2017,,, there are less than two years left,,,
I would like to work 24/7,
But although I have been known to go 3 or 4 days,
without any down time,,,
I usually have my brain pass out,
for two to three hours, every two to three nights,,, lol
Your Bro,
. . . . . . . . joe
Just one of His Creations:
EVil-sOLUTION – isn't it amazing just what the il-s of life can reveal
http://evotutionfairytale.yolasite.com/
I hope that I may be able to shake up this world
I want to dissolve this EVil-sOLUTION fairytale
I would like to know how their Humanist scientists explain
How does our moon remain in its orbit
With the constant addition of space dust
We do not hear much about space not being empty
But it contains a steady stream of dust partials
Messing up the mass + the trajectory of orbits
+ Why is there only about 6000 years worth of dust on the moon's surface?
PLEASE,,, do the calculations for yourself,,,,,,,,,,,,,,,,
https://www.google.ca/#q=calculating+space+dust+sediment+on+moon&*
(the moon is GOD's Creation hourglass = proof positive of earth's age)
So, how much space sediment would there be on the moon,
After billions of years of precipitation,,, billions of even mm's of sediment,
Is still equal to many meters of sediment,
+ how much is on the lunar videos,,,,,,,,,,,,,,
LESS THAN AN INCH
This proves that our earth cannot be billions of years old
Isn't it amazing, that if you calculate the total amount,
That it works out to be just about 6000 years worth of sediment
Exactly what the Holy Bible predicts
If you find yourself alive today
Get use to it,,, life is forever
Your going to be here for the long run
That's Forever + Ever,,,
You only have one choice,,,
--- Where to spend eternity
--- --- Heaven =(place where God Is + Rules)
.   .   .  .   .   or
--- --- Hell =(place where God does not rule)
Choose Christ today + become Born Again
(John 3:3)="Except a man be born again, he cannot see the kingdom of God."
that_prophet
TIME IS VERY SHORT, as we are not only living in THE END TIMES,
- but all who are BORN AGAIN + LOOKING FOR HIS RETURN
= have LESS THAN TWO YEARS to live,
before the DOOR CLOSES on the BLESSED HOPE occurring
when MILLIONS VANISH off this earth
BEFORE JAN 15, 2019 when=  1st DOOR closes: http://2020-vision.yolasite.com/
Of which, the 2nd ½ of this duration, is known as the "GREAT TRIBULATION"
We are allowed to "know that it is near, even at the doors-(close on last day)" (Mat 24:33)
« Reply #160 on: April 01, 2017, 11:44:15 AM »
PLEASE,,, DON'T LET SATAN (the beginning of lies) + EVIL FORCES HIDE THIS PRE- SCHOOL SIMPLE "GEM" OF A FREE ENERGY TECHNOLOGY ANY LONGER
I received this from God, after asking for a way to help the Tribulation Saints survive the soon coming Great Tribulation. http://doorschristmustpassthrough.yolasite.com/ I was first given a Vision of a 10 speed bicycle going uphill in 10th gear, and then back down in 1st gear. Which is very significant, considering that AC electricity is made from rotations of a coil of wire inside a field of 2 magnets. Then I later thought that it might have been an evil spirit leading me in the wrong direction, so I ask my Father to show me it was from Him, and not just evil spirits leading me astray. He Graciously pointed me to Ezekiel 1:16, where Ezekiel was trying to describe how a running UFO motor worked, "wheel in the middle of a wheel", or as I saw it, wheels inside of wheels. Since I did not have any thread technology where I could put wheels inside of wheels, I went with pulleys and a belt.
« Last Edit: April 01, 2017, 10:29:22 PM by that_prophet »
« Reply #161 on: April 02, 2017, 12:28:22 AM »
as in, the age of Christianity, (before waiting Born Again Christians are taken up in the clouds)
As Jerusalem was needed, it was part of the 70 X 7s
Which 69 of have already happened in the distant past
+ the last week is the infamous 7 year peace treaty with Israel + Europe + others
Of which the last half is "the Great Tribulation"
And 2026,(2025.94) is the 2nd DOOR, (when Christ sets His Foot on the Mount of Olives)
Your Bro,
. . . . . . . . joe
EVil-sOLUTION – isn't it amazing just what the "il-s" of life can reveal
I would like to know how these Humanist scientists explain
How did our moon remain in its orbit
With the constant addition of over billions of years worth of space dust
even billions of years worth of nanometers
LESS THAN AN INCH
Isn't it amazing, that if you calculate the total amount of dust
Exactly what the Holy Bible says that it should be
then I suggest you get use to it,,, life is eternal
That's Forever + Ever + Ever,,,
--- You only have one choice,,,
--- --- Where to spend this eternity that God has locked you into
--- --- --- Heaven =(place where God Is + Rules)
.   .   .  .   .   or
--- --- --- Hell =(place where God does not rule)
Life in what we call reality is more like we were mere images on a video screen
Matter has no substance, we only see + feel it because of the specific energy it has
Minute particles spinning around orbits so quickly, that it appears to be in every position at all times
That is slowly wearing down, think of atomic halflife
Your spirit is the part that is eternal, (how do spirits evolve)
All matter was created by God
How can we believe this ridiculous Humanist doctrine that states in text books, as if real science
These super complex atomic structures, (Which man cannot even conceive how to create)
Were all made from a big bang = (this takes more faith than any other religion)
Explosions destroy not create
that_prophet
This works on the simplicity of only having to pay the small amount of electricity, (massive voltage + only one spark of current) for the one single rotation of a DC motor with a large 100 cm circumference pulley attached. Then you take the 100 cm of moving belt, that comes from the one rotation of your 100 cm circumference pulley, and run it past 10 of the 1 cm circumference pulleys. This would multiply your # of rotations to 10 X 100 = 1000, and if you added AC generators to these 10 mini-pulleys you would gain a total of 1000 cycles of AC electricity.
These AC generators would run free of most any torque, as they are just winding up massive voltage,(which is what you need to crank over your DC motor=electrical pressure) as the only current that they need to generate is the one spark, or practically zero. You only need to generate one spark of current, because that is how much current that it takes to rotate your DC motor, with the 100 cm circumference pulley one single time. Of course you would also need 10 full wave bridge rectifiers, (4 diodes each) to convert your AC outputs back into your DC input.
you are trading one rotation of a 100 cm circumference pulley, (taking massive voltage) for 1000 rotations = 100 rotations each from 10 mini-pulleys with AC generators (creating massive voltage)
