GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
there are no need for extra batteries,
this works on the same GEM technology as mine does,
you are only paying for a little more power to rotate the larger pulley, (higher voltage to turn it)
yet you get many times, (10X) the amount of  moving belt off the large pulley,
+ when you run this larger length +(10 cm) of belt past a 1 cm circumference mini-pulley,
you would get 10 rotations, Now, if you added an AC generator to this mini-pulley,
you would get 10 cycles of AC electricity, for only one rotation of your drive motor,
that's 10 cycles/rotations of AC electricity, for every one rotation of your DC drive motor, (= multiple)
+ there is no torque problem, as the AC generator is free running,
because it does not have to generate practically any power,
only the little bit of current that a DC motor takes to rotate one single time
+ please don't forget that you can gain another multiplication factor, (doubling it with every addition)
-   by simply adding another mini-pulley + AC generator
so, if you added 3 of these mini-pulleys, with free running AC generators attached,
you would gain 30 cycles of AC electricity
+ don't listen to the torque problem, as these AC generators generate no power = no torque
as they only have to generate the small "spark" of current needed to crank the DC drive motor over one single time,
which is practically nothing, + zero times anything is still equals zero,,,
Quote from: Low-Q on June 13, 2017, 06:57:37 AM
The largest motor have a much smaller rotor than original. This will make space for a small battery inside (multiple button cells). The battery is connected to the terminal and the commetators/brushes when the rotor is turned fast enough (Centrifugal switch).
Therefor he measure zero voltage on this motor when it's not running to "convince people this is not a hoax.
There is videos on youtube revealing this trick.
Vidar
Low-Q
Unfortunately you're wrong about the concept. There are loss in the belt, pullys, motor, generator, electronic voltage regulator, wires etc. The 10 to 1 ratio is only a gear ratio.
Analyze the torque multiplied with RPM for both wheels. If one is ten times different, the torque is also ten times different.
The voltage measured on the largest motor while running is surprisingly stable close to 12V. While the voltage measured on the small motor is very close to 5V. By "accident" very suitable for the USB output. The voltage regulator (electronic circuit) is the cause of the stable 5V output.
The energy is not only the voltage. You must multiply it with Ampére. Energy P = U (Volt) x I (Ampére). I see no Ampére measurements in the experiment. So the energy is supplied from a hidden battery. The classical way is to hide inside the motor.
I've been working with such motors and voltage regulators for many years. I know exactly in detail how they work.
The video is fake. Sorry.
Vidar
Quote from: that_prophet on June 13, 2017, 10:56:23 AM
that_prophet
.      This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it.
.     Now, you have just multiplied your single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
.     If you run wires from your AC generator output, + put them into the input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn.
.     You must have your AC generator + your DC drive motor of the same voltage.
.     This is so simple + cheap to build guys + gals, please build one to prove it works,,,
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
.     So we have less than 19 months to live, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope" http://my2020vision.yolasite.com/ http://beliefstoliveby.yolasite.com/
Low-Q
@that_prophet
You might not have much time to live, 19 month as you say (how can you be so sure?). According to a few religions, we humans has been soon ending our life and will travel into the heaven for thousands of years. Why are you so convinced it will end in 19 months, when we have been wrong for thousands of years? Get your feet on the ground, and get sane :-)
Anyways, repeating your claims about your OU does not help. You've got an easy and straight forward explanation why your idea won't work.
I recommend you to move on, and spend the rest of your assumingly 19 month of life, to do something more important. Be with friends and family.
A meaningful life is not chasing the undoable, but spending your time with your loved ones and make a change where it is possible to make a change.
I respect your guts to move on with the undoable, but you're banging your head against a wall here. You can keep on doing that for the next 19 months, but it is very counterproductive :-)
Br. Vidar
that_prophet
Quote from: Low-Q on June 16, 2017, 04:26:04 AM
@that_prophet
I can be so sure because Scripture says we can "know it's near, even at the doors"
Did you ever wander why it says that you can know that it is near,
Near to what, if you're not allowed to know the day, how can you know that it is near?
Near to the door/deadline, because we are told that you can know the generation.
+ I used 51.6 years for the last generation, as it was used to predict the year of Israel's rebirth as a nation.
It is also calculated from the ling of Jesus, from the birth of Abraham to Jesus, the 12,12+12
This may not be the right duration for the final generation, but it sure seems the best to me,
I think this generation started when Israel took Jerusalem, as the Holy City was part of the 70 7s,
Which the last 7 is the final 7, before Christ comes back to earth,
To Rule for His Millennium = 1,000 years
Others were wrong because they were trying to predict the day of His arrival,
Which we are warned that we cannot know
My feet are on the ground,,, for now... lol
Yes, I believe that once conceived, we are all in this life Gift forever,
We all live eternal, + we only get a choice of where to spend our eternity,
With a Loving Father + Big Brother + Holy Companion, Who will be with us for all eternity,
All Three Personages Who love you + care about how you are doing, helping us always.
Or,,, without God to help us, in a place where we have to fend for ourselves,
In a place that is worse than hell, surrounded by evil people + evil spirits,
Both of which do not care about you, + are just fending for themselves,
+ remember that all of these fallen angels that are surrounding you,
Have a deep seeded hatred for us humans,
Blaming all of their troubles on us humans,
Because God chose us to be His Greatest Creations
I keep repeating it because you can't seem to understand the simplicity of it,
You are using the pre-school simplest technology of pulley mechanics to multiply your rotations,
+ AC electricity is made of rotations, so you are effectively multiplying you AC cycles of electricity
Effectively, you are using simple pulley mechanics to multiply your amount of AC electricity
Thanks for the recommendations, but I know that the Tribulation Saints will need this GEM tech,
To survive the coming Great Tribulation = (the 2nd half of the 7 year peace treaty with Israel)
I think that a meaningful life is one spent close to God our Creator
Doing His Will, which I think finding free energy for the Tribulation Saints most surely is,,,,,,,,,,,,,,
Br. Vidar
I said my life on this earth will end
As in, I will be going to Paradise for a little over 7 years = the 2520 days
+ the time before the 7 year peace treaty, that my Lord chooses to remove us from this earth,
This is simplicity at it's best, where you are using the longer length of belt,
That comes off a large 100 cm circumference pulley,
To run past a mini-pulley or 2 or 3 for that matter, of only 1 cm circumference,
+ multiply your rotations by 100, 200 + 300 respectively.
Where by simply adding free floating AC generators,
You are easily multiplying your AC cycles of electricity
It is truly that simpler,,,,,,,
Can you believe how much influence these evil spiritual beings can be,
To be able to hide this super simple pulley technology from us
