GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Thank you SkyWatcher
Yes,  I believe that any who try to build this GEM technology, will find themselves under great persecution from evil spirits. But this technology does work, and I was hoping to explain well enough to prove, with no good results. I don't understand why people do not see the Truth in this free energy system. You only need to produce a very small amount of current, (1 spark) only enough to rotate your DC motor, with a 100 cm circumference pulley attached, only one single time. That will give you 100 cm of moving belt, which you can run past one pulley of 1 cm circumference, with an AC generator attached, returning you 100 cycles of AC electricity. Now, try and tell me that you cannot get one single spark of DC current, out of these 100 cycles of AC electricity, to power your large DC motor + a 100 cm pulley one single time. PLEASE,,, explain to me what part of this free  energy mechanism will not work.
Quote from: SkyWatcher123 on August 27, 2017, 10:30:09 PM
Hi all, Hi paul-r, that is not correct, i was attempting to put something together, though things transpired around me of a negative nature and i could not go further.
Does this mean that something is resisting attempts to build some kind of replication, i don't know, we should really ask ourselves that question.
that prophet should be allowed to continue posting, though yes, if it is the same topic of discussion, there is no need for multiple threads.
Also, to share my thoughts, unless one has tried to build his device with a genuine effort, then i cannot see how one can conclude anything.
peace love light 8)
that_prophet
When it comes to electronics, it is not me that has a lack of understanding,,,
I built + wired a 32' by 16' by 2 story addition to my mom's house in grade 12 # 2, (failed English)
+ I rebuilt + rewired everything past the firewall on a Datsun B210 in my Christmas break at UNB
+ I designed + built a wiring harness to connect on/off switches + batteries for my Halloween costume
Which connected over 200 LEDs, a light chaser, helmet fan, switches, batteries + voice amplifier on it
+ I made 80's in 2.5 years of electrical engineering at UNB, New Brunswick, Canada
So I believe that it is you guys + gals that have the lack of understanding,
Mostly because of you're listening to the ever present voices in your heads,
These voices are from evil spirits, that are trying to + have been hiding this simple technology from mankind,
+ they seem to be doing their jobs extremely well, as everyone seems to be listening to them,
Instead of paying attention to my reasoning, and listening to my logical explanations.
My proposal is to use the minuscule amount of DC current, (one mere spark of current),
To rotate a DC motor + large 100 cm circumference pulley one single time,
Then to use the 100 cm of moving belt off of the 100 cm circumference pulley,
To run past 1 to 10 of the 1 cm circumference mini-pulleys, with AC generators attached,
Notice that these AC generate would rote extremely easily, as they are just winding up massive voltages,
As great amounts of torque, is only needed when you generate power, + P=IV OR,
"P"ower = "I"-current multiplied by "V"oltage, + we only need a small amount of I"-current + "P"ower,
Gaining you 100-1000 cycled of AC electricity, + all from the one single burst of DC current,
Then you put this AC electricity through a full wave bridge rectifier,
This will give you massive voltage + the mere one single spark of current to rotate your DC motor once.
You only need the one spark of DC current, because the single rotation of your 100 cm pulley,
Gives you the 100 cm of moving belt that you need to run past your 1 cm circumference pulley,
With the AC generator attached, giving you 100 rotations, or 100 cycles of AC electricity.
This mini-pulley + AC generator is the easiest to rotate, because it is only winding up massive voltage,
Needing practically no current, as it only has to generate one single spark of current,
The one spark, is just enough current to rotate your DC motor + 100 cm pulley one single time,
This small amount of DC current/electricity, would be just enough to give you 100 cm of moving belt,
Which is easily run past one single 1 cm circumference pulley, with an AC generator attached,
+ guess what this half of the GEM mechanism could be giving you, yes 100 cycles of AC electricity.
Torque only comes from when you are generating more power, and because power is equal to current multiplied by voltage, and although you are winding up massive amounts of voltage, you only need one single spark of current. (which is practically zero). So, even massive voltage times practically zero current, times practically zero current, is still equal to practically zero power, costing practically zero torque to generate.
This can be done, because these mini-pulleys are easy to rotate,
As they do not have to generate practically any amount of power,
They are just winding up massive voltages, which takes very little power,
This is because the only amount of current that you need to generate is one mere spark,
Because the only current that you need to generate is just enough to rotate a DC motor once.
Please explain to me exactly why this will not work,,,,,,,,,,,,,,,,,,,
Each side of this mechanism produces more than enough of what the other side needs.
The massive amounts of rotations of the mini-pulleys produce massive voltage,
Which is needed to rotate your DC motor with one large pulley one single revolution
+ the one rotation of the large pulley, generates a 100 cm long length of strap,
Which is what your mini-pulleys need to produce many rotations, giving you massive voltage.
+ this massive voltage is just what you need to crank over your DC motor once,
Giving you the 100 cm of moving belt, to pass by your 1 cm mini-pulley, giving you 100 rotations
Open source was what I was trying to do, before Obama changed the patent laws, so that anybody can patent it. Before he did this, once I published it http://free-energy.yolasite.com/, which I did in the early 2000's, only I could patent it, + I was never going to patent it,,, leaving it open source.
that_prophet
Temporal Visitor
Quote from: Temporal Visitor on August 27, 2017, 03:44:11 PM
Here is why, in case you do not know it;
"HORSEPOWER is the only "POWER" that is capable of driving a conventional alternator/generator on this planet."
Yes, but the only amount of horsepower that is needed to drive this GEM mechanism is practically none
As you only need to generate one extremely small amount of current, just enough to rotate your DC motor once.
That is because that is all that this GEM mechanism needs to rotate your DC motor once,
As this one rotation of your DC motor, with the 100 cm circumference pulley attached,
Would give you 100 cm of moving belt, which is used to gain you 100 rotations of a 1 cm circumference pulley,
That has am AC generator attached, giving you 100 cycles of AC electricity,
+ then you add another spark=(short burst) of current, and start this system all over again
What you loosely propose is not capable of providing and does not provide the single thing that is REQUIRED.
Do you even read my text,,, please give me specifics on what you don't believe works + why it doesn't,
I have not seen one thing that goes against my GEM technology workings
I got 80's in my 2.5 years of electrical engineering at UNB college, so I know a little about what I speak of
If you care to: you can read more about that sentence here: http://www.backgauges.com/Gen-E-Sys%20II/power.html
I took 2.5 years of Electrical Engineering, so I have already read plenty of info on this subject + what I see as your biggest problem with my GEM technology is torque, which I see that there is very little of, and you seem to think is a major problem.
Sparks just will not cut it to keep a POWERPLANT generating POWER.
I say spark because that is what I call the minuscule amount of DC current/electricity that the DC motor takes to rotate one single time. That is because this single rotation of the DC motor, with a 100 cm circumference pulley attached, is all that is needed in your one half of this GEM free energy producing mechanism. This gives you 100 cm of moving belt, to pass by your 1 cm mini-pulley, which gives you 100 cycles of AC electricity
Yes the screwdriver comment/remark by Pulp is a good clue as to what you missed.
Sorry, but I do not care to know, just what his dig was supposed to be all about.
I think that it is awful hard to get others to listen to someones reasoning + logic,
(which is being craftily hidden by evil spirits), when you bring any insults into this conversation
that_prophet
In this two pulley mechanism, you have one large 100 cm circumference pulley and one small 1 cm circumference mini-pulley. This mini-pulley + AC generator runs freely, as it is just winding up massive voltage, and does not need to generate practically any current at all, (only one spark). Torque comes from generating power, and if you only have to generate one small burst of current, (practically zero) you would be producing practically zero power, which takes practically zero torque. Your drive motor only takes the one spark, or short burst of current, as this is all that we need to crank over the DC motor one single time, and rotating this large 100 cm circumference pulley.
This gives you 100 cm of moving belt, that you can run past a single 1 cm circumference mini-pulley, with an AC generator attached, gaining you a return of 100 cycles of AC electricity. This mini-pulley is extremely easy to rotate, even with the AC generator attached, because with all of these 100 cycles AC electricity, you only need to produce the one single mini-burst of current. This is because one short burst of current is all that it takes to rotate a DC motor one single time. This AC generator takes practically no torque to rotate, because torque is only caused when producing power, and you only have to produce a single burst of current. This is because no matter how great of a voltage you generate, it is still multiplied by practically zero current, which would equal practically zero power, costing practically zero torque.
By the way, my system only shows you one rotation of the DC drive motor, so that is why I do not deal with rpm stuff. Although the other end of the belt drives the mini-pulley 100 revolutions, I only deal with the single revolution of the DC drive motor. This one rotation of the drive motor, through pulley mechanics, giving you 100 rotations of a 1 cm circumference mini-pulley, and if you attach an AC generator to it, this will give you 100 cycles of AC electricity. This works because each side of the system produces more than enough of what the other side needs. The massive rotations of your AC generator would produce massive voltage, which is just what you need to crank over your large 100 cm pulley + DC motor the one single revolution. The DC motor has a large 100 cm pulley to drive your 1 cm mini-pulley 100 revolutions, giving you 100 cycles of AC electricity. This would give you plenty of voltage-(electrical pressure) to crank over your DC motor the one single time.
Can you believe the power that these evil spirits have, keeping this super simple free energy technology, where you are using pulleys to multiply AC electricity. This is so simple that it's totally ridiculous that we have not discovered this a long time ago, like as soon as we discovered how to generate AC electricity. I hope this makes you angry at the deception, and maybe even gets you to build this super simple AC electricity multiplier. First, please let me give you a strong warning, because as soon as you start trying to reproduce this GEM free energy technology, you will run into many bad things, which will not let you finish building it.
Everyone will try to convince you that it is a stupid idea, maybe even threatening your friendships, if you continue with building it. There will be so many bad things happening to you, which you will surely choose to stop your work on this super simple technology. If you do not stop trying to build this GEM=(Geometrical Electricity Multiplier), then I cannot tell you what these evil spirits will do. Think about how super simple this method of using pulleys to multiply AC electricity truly is, and realize that there may have been many who have died try to get this GEM technology out.
Would you like to be told, just how super simple this free energy mechanism is, and the easy to build this simple technology of using pulleys to multiply AC electricity. You only need 2 pulleys, one large one + one small one, one DC motor + one AC generator of the same voltage, a full-wave bridge rectifier, the wires to connect these units together, and the hardware to put this mechanism together. These pulleys are attached together via a belt, strap, elastic or even a tied length of string or rope. Remember that this GEM tech needs to be easy + cheap to build, as it will have to be built by Tribulation Saints, people that cannot buy or sell. This lack of doing commerce is because they choose not to take the mark.
They are extremely wise in not taking the mark, which includes some sort of worshiping the anti-christ, because taking the mark will mean that they are assured of spending eternity in the lake of fire, a place that it is even worse than hell. Although they will eventually be forced to take this mark, because not taking the mark, will eventually mean that you will be beheaded. By the way, does this type of execution sound like any religion that you know of? Now, I dare you to try and build this super simple, and super cheap to build, free energy, electricity multiplying GEM technology, and please be careful, as these evil spirits will soon be turning your life upside down.
that_prophet
The large 100 cm circumference pulley, which is connected to a DC motor, and only has to rotate the
one single time, costing only one spark of current, an extremely small amount of, (practically zero)
electricity to rotate. This single rotation would give you 100 cm of moving belt, which you could easily
run past 1 to 10 mini-pulleys of 1 cm circumference with AC generators attached, giving you a return
of 100-1000 cycles of AC electricity.
These mini-pulleys rotate extremely easily, as even though these AC generators are winding up massive
voltage,(which is exactly the voltage pressure that you need to crank over your large pulley the one single
time) they only need to generate the one mere spark of current. Generating power is what cost you
torque to rotate, and since you only need one spark to rotate your DC motor for one revolution, which
is practically zero current, you are generating practically zero power, taking practically zero torque.
