GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Hello fellow inquisitive one, . . . . . .  . . . . .  . . CHRISTIAN AGE ENDS 2019.04 = 1st DOOR closing.
Ezekiel 1:16 speaks of a UFO motor as "wheels within wheels". This self powering set of motors
https://www.youtube.com/watch?v=NxpoiCFKmPg is almost identical to the GEM idea that I was showed. Free energy is as simple as imputing one short burst on DC current, to drive a large 100 cm circumference pulley for one single rotation. This could move 100 cm of belt past 1 to 10 mini-pulleys of 1 cm circumference, each with AC generators attached, gaining you an output of 100 to 1000=(10X100) cycles of AC electricity. If you used an AC drive motor, this pulley technology, could be simply multiplying one cycle of AC electricity into 100 cycles of AC electricity. http://free-energy.yolasite.com/
How can you not gain the minimum amount of electricity that it takes to rotate a DC motor one single time. Especially when you can have 100's  or 1000's of cycles of AC electricity to use in acquiring this small amount of electricity that it costs to rotate a motor one single time. Now you have a self powering set of motors, that you can tap power off of. This could be any voltage he you choose, and the more mini-pulleys that you use, gives you greater ability to draw current though your taps off these running motors.
+ with this single rotation of the 100 cm circumference drive pulley you would gain 100 cm of moving belt, which through attaching AC generators to 10 mini-pulleys of one cm circumference, will give you the 1000 cycles of AC electricity. Each side of this dual motor mechanism will gain you more than enough of what the other side needs, which makes this a self powering mechanism.
http://doorschristmustpassthrough.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/    otat
http://biblefilescentral.yolasite.com/
https://www.youtube.com/watch?v=O1vtx5sDxrg
that_prophet
This should be extremely obvious, yet evilo forces are clouding our minds with lies about torque being a problem. This works because it does not cost 100 times as much power to crank over a 100 cm circumference pulley as it does to rotate a 1 cm circumference pulley. Yet, if you ran the 100 cm of moving belt that comes off of the single rotation of a 100 cm circumference pulley, and ran it by a 1 cm circumference pulley then you would gain a multiple of 100 rotations, which by adding an AC generator, you could easily turn into 100 cycles of AC electricity.
So, you can convert a few pulses of AC or DC eletricity, used to rotate a 100 cm circumuference pulley only once, into 100 cm of moving belt. Then by simply attaching an AC or DC motor/generator, this can be converted into 100 cycles of AC or DC eletricity, for every 1 cm circumference pulley that you choose to add to the same belt as the 100 cm circumference pulley is attached to. If you added 10 mini-pulleys, then you would be able to gain 1000 cycles of AC or DC eletricity, and all from a few short bursts of AC or DC eletricity.
free energy is done using pulleys,,,,
TRY THIS OUT FOR SIZE,,,,,,,,,,,, THIS IS ALMOST IDENTICAL TO MINE = https://www.youtube.com/watch?v=NxpoiCFKmPg
This simple mechanism uses different sized pulleys to freely multiply the # of rotation.
I use the single rotation of a 100 cm circumference pulley can freely and easily be converted
into100 rotations of a 1 cm circumference pulley.
So, through simple pulley mechanics, we can multiply one rotation,
of a large 100 cm circumference drive pulley,
into 100 rotations of as many 1 cm circumference pulleys
that you choose to add to the same belt as the 100 cm drive belt..
This works because of the circumference change in the pulleys
« Reply #1 on: September 17, 2016, 11:37:08 AM »
can you believe that I was first given this technology in 2000 or 2001, + soon published it on the web @ http://free-energy.yolasite.com/
+ nobody would listen to my idea of using pulleys to multiply AC electricity
I was hindered by evil forces + my friends and family,
were deceived by evil forces, and would not help me in building it
THANK GOD !!!
I have been trying to tell people about how simple free energy could be,
by using pulleys, we could be freely multiplying AC electricity, or even DC apparantly.
Somebody has built one very similar on UTUBE,,,
@ https://www.youtube.com/watch?v=NxpoiCFKmPg
my mechanism used AC generators + a full wave bridge rectifier.
I did not realize that you could use a DC motor both ways,
with DC in, as a motor + as a generator, giving you a DC output also
FREE ENERGY IS NOW HERE,,, FOR ALL TO USE AS MUCH AS WANTED
I truly cannot see how Satan + his evil 1/3 of angels,
as well as all the spirits of millions, if not billions of half breed creature,
that we humans experimented with before the flood,
that these can so easily hide this dirt simple technology,
with it only being the simple use of the long length of belt,
that comes off a large 100 cm diameter pulley,
to be run by a 1 cm circumference pulley with an AC/DC motor/generator
returning the free multiple of 100 cycles of AC/DC electricity
We can stop using fossil fuels +,,,,,
No more paying for gasoline,,,,
No more giving terrorists our money.
This should start a massive amount of new free energy inventions.
Having everything powered by fossle fuels or electricity,
being recreated with it's own GEM free energy mechanisms being built into it.
No more polluting the air we breath, with gasoline engines,,, ALL ELECTRIC AUTOMOBILES.
No more polluting our atmosphere by heating our homes + workplaces
No more pollution for lights + cooking our food
that_prophet
   This works on simple logic, yet evil forces have kept it hidden all of these years. If you don't believe in evil forces, then please explain how this super simple free AC electricity multiplication using pulleys technology was kept hidden, and not discovered long ago. Pulleys can be used to drastically multiply the # of rotations freely. Since AC electricity is generated using rotations, then why cant we use pulleys to multiply the total  #  of cycles of AC electricity.
   So, you would only have to pay for the one rotation of a 100 cm circumference pulley. Then if you set up a mechanism that ran the belt off of the large 100 cm pulley, and ran it past 10 mini-pulleys of 1 cm circumference pulleys with AC generators attached, then you drastically multiply your cycles of AC electricity. With this simple set up of 11 pulleys, you could gain a return of 1000 cycles of AC electricity, and all costing you only the smallest amount of electricity that it takes to crank over your drive motor once. = 1 to a few cycles of AC electricity.
that_prophet
This works on the simplest of logic, as you only have to pay for the smallest amount of power to make a single rotation of a 100 cm circumference pulley. Then, by attaching 10 mini-pulleys of 1 cm circumference, with AC generators attached,,,,, YOU CAN GAIN A RETURN OF 1000 CYCLES OF AC ELECTRICITY = ALL FOR A FEW BURSTS/SPARKS OF AC OR DC ELECTRICITY<<< HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY = PAY 1 + GAIN 1000 >>> and please don't listen to the torque lies by evil spirits, as the only torque this needs to produce, is the small amount of torque that it takes to rotate your drive motor ONE SINGLE TIME =(practically zero, when you are talking about current)
that_prophet
THIS SHOULD END ALL DEBATES,,, WE CAN USE PULLEYS TO MULTIPLY AC ELECTRICITY,,,,,,,, + if we stopped listening to the billions of evil spirits -(which enjoy the money that we give to terrorist,,,, promoting terror) then we could be discovering how this " a wheel in the middle of a wheel" (Ezekiel 1:16) technology can be used in UFO's to gain anti-gravity
