GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
SkyWatcher123
Hi all, the alternator is a special modified one i bought many years ago, was planning to build a wind generator, but never did.
It is from hydrogen appliances online, it is a 48 volt model, i think #48120 and has a bridge rectifier built in and has neo magnets inside.
It was not cheap and is not necessary for this, i just had it on hand.
Multiple alternators would come later, not even at stage of input motor yet, more structure will have to be attached, to accommodate the drive motor to pedal sprocket.
peace love light
massive
this pic is an alternator I pulled from a car in 2006 and repurposed for a job I was doing at that time .
toyota 12v reg/rect.
Its illegal to use petrol or diesel in tunnels so I rigged up a gen , motor , alt , batt , Warn 12v winch and pulleys to shift 3-4 tonne mass
SkyWatcher123
Hi all, finished with the electrical for now, it charges well, it doesn't need much pedal speed or effort to get the 12 volt battery charging good.
I have a charger hooked up to the 12 volt battery, am charging my efficient nigh light, which has a 3ah 4 volt lithium ion.
I can even pedal while it's charging to help keep the 12 volt battery topped up.
Also have a volt meter on handlebars, so i don't push the voltage much past 15 volts.
peace love light
that_prophet
Hello SkyWatcher123,
.    Since you are a fellow Christian, I thought that you might be interested in hearing "the rest of the story", on how I came to discover this technology. I believe that this was given to me for helping the Tribulation Saints, after I asked God for a way to help them make it through the soon coming Great Tribulation. You see, I believe in the pre-Trib Rapture, and I figured that I would not be around to help them later on, during the Great Tribulation.
.   This also has another part to it, as I have always been very interested in the precise mathematics of Bible Prophecy, as this was how God proved to me that the Bible was Truth. It was a novel called "Armageddon", by the recently deceased Canadian author Grant Jeffery, and his systematically going through all the fulfilled Prophecies of the Bible, showing when they were given, and how they were fulfilled, right down to the exact day. To be exact, it was how the prophecy about Jesus entering the temple on the exact day that it was predicted, or should I say that it was His Rule of giving a second chance, after 10 times the original duration,,, that it predicted when Israel would become a nation, right down to the exact day, May 14th, 1948.
.   We are warned, that no one knows the day or hour of His Return, but we are also told that we can "know that it is near", near to what, it cannot be the day of His arrival, because no one knows this date, maybe it is the door or deadline, because we are allowed to know when it's "even at the doors".  Doors are plural to represent His both Comings, one to meet His born again followers in the clouds, and then a second time, when He sets His Foot on the Mount of Olives.
TIME IS VERY SHORT, + WE ARE LIVING IN THE END TIMES...
Why I believe that ISRAEL'S 7 YEAR PEACE TREATY MUST START
BEFORE JAN 15, 2019 = http://2020-vision.yolasite.com/ = 1st Door
+ http://doorschristmustpassthrough.yolasite.com/
Of which, the second half of this duration, is known as the "Great Tribulation"
When Satan + all of the fallen angels + their offspring = (aliens + giants)
Will be sent to this earth, "woe to ,,, earth and of the sea!" (Rev 12:12)
Remember that although we are warned "that day and hour knoweth no man" (Mat 24:36)
We are allowed to "know that it is near, even at the doors" (Mat 24:33)
Because we are "this generation shall not pass" = (Mat 24:34)
But in the original Greek, we are told that we must know, as in, this is worded more like a command. (Mat 24:33) "know that it is near," near to what = the door, as we are allowed to know when it's "even at the doors". These doors close on the deadlines, or when prophecy can no longer be fulfilled. Or, the day after the last day that that this prophecy can still be fulfilled, + the doors are plural, to accommodate His two arrivals = (Rapture + Glorious Appearance). Where the First Arrival is before the 7 year peace treaty begins + His Second Appearance is immediately after the peace treaty ends.
In (Mat 13:39) it says "the end of the WORLD"
Now hold on,,, our world is never going to end,
Proof= (Isaiah 45:17) + (Ephesians 3:21) = "world without end"
Where it is mistranslated + should I say "end of the AGE"
as in, the age of Christianity, until the rapture occurs
(before the born again Christians are taken up in the clouds)
then using 51.6 as the duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)= linage of Christ
+ also used to accurately predict Israel's rebirth, to the day
Starting with 1967.44, (when Israel took Jerusalem)
As Jerusalem was needed, because it was part of the 70 X 7s
Where the last 7 includes the infamous 3.5 years of the Great Tribulation
MATH : 1967.44 + 51.6 = 2019.04
adding (6.9solar) = the 7 Hebrew year for the Tribulation,
then as for when the door=deadline closes for Christ setting His foot on earth,
we would get 2025.94 = 2019.04 + 6.9
These evil spirits have been, + are continuing to work hard at hiding this super simple free energy technology from us, for all of man's His-story, or at least since Ezekiel wrote his description of how it worked. AC electricity is created by rotations, and we can use varying sizes and the # of wheels/pulleys to multiply your total # of rotations, + thereby multiply our AC electricity. This works because your AC generators do not give any resistance unless you are drawing any amount of power off of them, and since you only need one spark of current,(practically zero) to rotate your DC drive motor once, keeping it running. Since power,(causing torque) is equal to current times voltage, or P=IV, and one spark of current, (practically zero) times even massive voltage, is still equal to practically zero.
Quote from: SkyWatcher123 on January 30, 2017, 09:10:16 PM
peace love light
SkyWatcher123
Hi that_prophet, thanks for sharing, nothing surprises me much anymore, different body, different earth geography, apparently anything can be changed and seemingly in a blink of the eye.
I comprehend the theory of this device and it makes sense to me.
I just realized i can hook up the drive motor to the rear bicycle wheel sprockets, which should make it easier to implement, as the structure is already there to mount the motor.
So based on your theory, we should be able to power the motor, turning the large wheel, in turn rotating the small pulley attached to the alternator and then take the electrical off the alternator and direct that into the drive motor, giving us a self runner.
Though if we have a large enough excess, then we can instead, take the electrical off the alternator(s) and charge batteries.
While these batteries run the drive motor and we can then take the remaining excess from the batteries, in the hope we never deplete the batteries below what we started with.
I have a 24 volt-200 watt scooter motor, i will start planning and see how that works attached to the the rear wheel chain sprocket.
