GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
massive
you have to delete the word "SPARK" and the word "UNIT"  , these are not electrical measurements in Electrical Engineering
that_prophet
So, do you admit that this pulley technology works at multiplying AC electricity?
Quote from: massive on February 13, 2017, 03:01:58 PM
This uses the simplest GEM technology,,, by paying to power a DC motor to rotate once, with a 100 cm circumference pulley attached =(only one very small amount of current). This can produce you 1000 units of AC electricity, by simply adding a belt that is long enough to wrap around your 100 cm circumference pulley and 10 more 1 cm circumference pulleys with AC generators attached.
These AC generators run free of practically any torque, because you only need to generate such a small amount of DC current to drive your DC drive motor and you have 1000 rotations of AC generators to add up to your very small amount of DC current, which you must run your AC output through full wave bridge rectifiers to convert into DC.
Paul-R
Quote from: that_prophet on February 17, 2017, 05:54:47 AM
"No" and "Meaningless".
The best way to nudge you to an understanding, that_prophet, is to ask you to explain how a gearbox works and why it is useful.
massive
you have used the word "units" again , theres is no such thing .......... only trying to help you out here .
when you increase speed you increase the frequency of AC = alternating current
as for the pulley ratio , if the DC (direct current)  motor is revolving 1000 rpm , what rpm is the alternators spinning at ?
from that number of rpm you can calculate the frequency of the AC output of the alternators
theres a formula for that , used in electrical engineering
one positive out come of this thread is ...
http://hydrogenappliances.com/
Low-Q
What you are doing with the 100 cm circumference pulley and couple it to a 1 cm circumference pulley with a belt is to achieve a gear ratio 100/1.
What is this gear ratio doing?
Well, it will make the 1 cm circumference pulley take 100 revolutions while the 100 cm circumference pulley takes one.
Not only that. The torque you measure at the 1 cm circumference pulley is 1/100th of the torque on the 100 cm circumference pulley.
If you multiply the gear ratio with the torque ratio, you get a total energy gain of (100/1)x(1/100)=1. If you put a million lossless systems in series, you still got an energy gain of 1 - because 1x1x1x1x1x1x1x1x1x1.....(a million times)=1.
Vidar
