Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
Floor
@ all readers
Here are some links to demonstration videos on this stuff.
                                    @         http://www.dailymotion.com/video/x59r978
There are  TWO OTHER VIDEOS there, which describe the test device.
One is titled                          "magnet force test"  @          http://www.dailymotion.com/video/x4p1ome_magnet-force-test_tech
The other is titled                 "newTD2"                  @         http://www.dailymotion.com/video/x4phd00_newtd2_tech
All three videos were done by me under the user name " seethisvid" .
Here is a link to related work done by "GoToLuc"  https://www.youtube.com/watch?v=bmCQVg9qRmQ
                         floor
norman6538
Floor attached is your drawing that I made and tested. I was hoping that the magnet stack would turn off and on the repel forces but it does not.
I wanted to turn the repel force off and on to get net work.
Norman
Floor
@Norman6835
Quote from Norman6823
"Floor attached is your drawing that I made and tested. I was hoping that the magnet
I wanted to turn the repel force off and on to get net work."
End Quote
Yes I see......  a partial, of a drawing .... I drew .....  and I hear you say that you "tested" it.
                               BUT
I went ahead and tested a thin magnet shield configuration for my self.  I did this
only because of some of your statements here.  My observations are the ( RtAngSld 3-1.PNG ) file above.
On a basis of Knowledge.... I fully expected my test would contradict what your statement
                              "the repel force is not turned off"
                                             seems to imply.
                            What I found,  flat out contradicts what is implied in that part of your statement
        "........ the magnet  stack would turn off and on the repel forces but it does not."
Your claim a fail.... and that statement implys that the principle I demonstrate is invalid.
You still haven't show us your measuring device or how it was used....
                                                     or
                            for that matter any measurements.
At this point,  I don't believe that you actually have a valid method and / or test device ... at all.
You should have been clear that it is your methods and test device that are the fail, and that they
cannot yield any more valid information than ...... that your methods were a fail.
                           Please stop posting on this topic.
        floor
Floor
@all readers
That png file  "RtAngSld 3-1" again here below.
                  floor
citfta
Webby1 if you look at a recent video Floor posted it clearly shows the force to remove and reinsert the shield magnet is zero "IF" the other magnets are properly aligned.  If they are off by only a few degrees then there will be some force either repelling the shield magnet or attracting the shield magnet.
Respectfully,
Carroll
