Is anyone seriously interested in Free Energy Physics?
Started by aether22, January 22, 2017, 05:31:43 PM
sm0ky2
Eds energy he called "magnetic current"
And for all intensive purposes, it fits this name
So I choose to use it, even though mainstream
Science declares it not to exist.
We can see it working in the PMH.
It behaves exactly like electric current
Without the electric vector.
The inverse to electrical resistance is the
result of the phase transition 90-degrees.
Which manifests as magnetic attraction.
The magnitude of the attraction is the induction
Of the applied field. If this field was electric, as
done with a coil in a PMH- the math tells us exactly
The quantity of magnetic current to expect, by using
the materials constants of the inducing ferrite.
The problem science has is mostly conceptual.
There are two aspects to magnetic resistance.
And together they are 'backwards' to how we think
about electricity.
There is almost no resistance to magnetic current in
most ferrites. They are all magnetic superconductors.
Almost all of the resistance lies in the other aspect.
Which is the magnetic induction.
This is where the electric field is converted to the
magnetic vector.
In a normal ferrite the phase transition is a sinosoidal
Process. Electric to magnetic to inverse electric to
inverse magnetic. And the cycle repeats.
This is used in two forms:
a rod-type ferrite (open magnetic circuit)
Or a loop-type ferrite (closed magnetic circuit)
The second type produces less magnetic resistance
For reasons described above, which is why we use
Closed loop magnetic inductors. But I won't get too
deep into that, as it tends to stir emotions with the
Electronics guys....
Anyways, back to magnetic current.
When we induce magnetism into the ferrite
And it is near another ferrite it also causes induction
But the induction is inverse to the applied field.
This is an attribute of the space between them
Not the air or any physical thing.
When we start out with an open circuit
And the fields are facing each other
And induction is occurring
Not only from the electric field
But also from the magnetic domain
Via the spacing
That moment when they snap together
The electric vector phases in with the magnetically
Induced field on each end of the gap.
The magnetic circuit shorts out.
And current flows eternally like an electrical signal would
in a superconductor.
This magnetic current (I theorize) is the force that impels
microscopic particles of ferrite into the foreign object
placed in the gap.
There is a time-based factor involved. But I had not the
tools to examine the exact nature of changes taking place
Other than the objects became inexplicably paramagnetic.
As if alloyed with a ferrite.
sm0ky2
At the same time, (actually 2-3 pages later in Ed's book)
We learned about negating the universal restriction
Generally attributed to spacial propagation
Otherwise known as:   c
Mind you, IBM had just announced, then quickly denounced
That they had done the same in the laboratory.
Aside from the millions in lab equipment and payroll
The only real difference between Ed's at home experiment
And what IBM was trying to do
Is that Ed taught us the on/off switch
IBM only observed the effects when they accidentally
Turned in on.
Then they would accidentally turn it off without knowing
How or why it would turn on or off.
They explained it as a wave propegation anomaly
and eventually stopped funding it.
But I took up the quest of understanding that part of things
and gave up on PMH research, I studied light.
What is light, what makes light
What makes light move at the speed of light
Why can magnetism and electricity move faster than light
But light can't. I was engrossed in this aspect of Ed's magnetism
until I met Dave. He found a way
to link the two with his split tube device.
Ed told us they were all the same.
But now we can actually see how magnetic current changes the phase
Of incoming photons.
sm0ky2
The thing with magnetic current
If it's not in an eternal loop, let's say
An open circuit, driven by an electrical source
The phase transition of the electric current into
The magnetic domain can set up magnetic currents
Through space. Think of it like a tiny wormhole
Between two points on you workbench.
Magnetic current travels through the space between
the two points. While this is going on, any impedance
that would normally be there electrically, goes away.
R=0 between these two points. Transmission is instantaneous.
The magnetic field in this current is the same as the field
That propagates ahead of a photon. The field the photon
'rides on' through space. This is what gives light the speed of c
The field itself propagates instantaneously, but the effects of the
flux caused by the field, occur at c
There doesn't need to be a wire to transmit magnetic currents!
And since we have unified the magnetic transition between electricity
and magnetic current.
Magnetic current and light
We can now propose that light can, create magnetic currents
If light from, say an image, were to converge in a certain way
Some distance from the source, and there was another source
A current could develop somewhere in the space between them.
I won't get into the electrostatic and electromagnetic effects of
screen technology, most of you won't even want to use your
computer anymore. That's like taking a magnet to a bowl of
Crushed up cherios or corn flakes....
This kind of thing could occur from reflections or shadows
Not to bring up the placebo thing again, but our human response
To visual ques is somewhat astonishing.
We can feel things we see
Especially when we don't know it's not real.
Then there's the whole cold water warm water thing
And the upside down eye glasses
A visual disturbance caused by magnetic currents
Could create a physical response, your mind expects something
to be there.
There could also be magnetic perception in your sensory system
A healthy human with enough iron in their blood, can detect fields.
Generally with their hands. Electric more strongly than magnetic, but
Both are reported.
Here we have two aspects of physical manifestation with no material matter.
What exactly is "matter"?
it's mostly empty space, nothing there but electric and magnetic effects.
and light, which is both.
sm0ky2
Another aspect to consider is thermal conductivity
For the same reason a piece of metal may feel colder or
Hotter than the room it's in....
Magnetism can change the thermal conductivity of atoms
and molecules.
A magnetic current in the air could alter the thermal conductivity
of a space and make it feel warm or cold, depending on the
Temperature of the person and the room.
You can feel these tiny spaces with your fingers.
aether22
I want to add something...
Smoky2, and I know he's not the only one says that feeling energy is not useful as evidence because he believes that the mind can "Imagine" sensations that are not occurring as a form of Placebo effect.
Now firstly, the mind is likely producing an energy sometimes when people feel something as intention can effect this energy, and things at the quantum level as demonstrated in Quantum Physics experiments.
But even if we concede that we can't trust physical sensations fully, does that mean we never use the sense of touch of feeling in our world to get around and do things?
In the same way people can see things that aren't there, but do we disregard sight?
And audio hallucinations exist.
And we can make mistakes in our thoughts and be deceived...
So why do I trust my life to my ability to drive when I could imagine the physical sensations, sights and sounds and even thoughts and screw up and die and kill others?
It's not even that I can claim these things could only happen to other people, I have "looked but not seen" before.
The reason we still use our senses, our mind even though our whole reality is subjective is because even though in some cases our senses can be fooled (we have all seen images designed to create visual illusions) is because it works most of the time.
Feeling energy from my images and coils is the same way, sometimes it might be too subjective...
Sometimes people might even imagine feeling a sensation that isn't created by my methods, or even create or change an energy with their mind.
But overall most people who can feel the energy are indeed feeling something that is actually there and the feedback they get from feeling is of use.
It just so happens that at this point in time the most important technological discovery we need to master requires trust in ones own senses as we do not yet have a suitable technological means to measure this energy well.
As for magnetic currents, I do think that there is an aetheric energy flow along magnetic fields lines, a magnetic current if you will.
And I do think that the aetheric current and the magnetic current can intermingle.
I still would say that while an interesting technique, the phenomena of a closed magnetic circuit with notable hysteresis maintaining a magnetic field is really not that extraordinary and does not need any special current to explain it.  Still I think one exists and when this energy is ejected out of an locked magnetic circuit and in doing so a pulse can be released that has extraordinary qualities as Norman Wootan has repeatedly found, it can couple into distant electrical components giving a powerful surge.  It's more than just conventional EMF.
