Sm0ky2's modified Voss Machine
Started by sm0ky2, January 23, 2017, 03:08:32 PM
sm0ky2
Constructed the new ion thruster
This one, I combined the magnetic thruster from India
(which I upgraded)
And the gridded Ion thruster from NASA
together, the double-accelerator rocket produces
incredible thrust for the input power (>18 mW)
Here is a video showing the thruster, and the first test clip.
Northstar MK1 Ion Impulse Rocket
https://youtu.be/In4W9LNMScQ
https://youtu.be/SR9PnawxLRM
sm0ky2
Dual Northstar rockets
With a new experimental Ion Emitter
https://youtu.be/D0sifJKeb_Q
sm0ky2
It appears our friend Paul Baumann was right after all :)
But before I get to testatikification of my machine......
I want to run his voltage converter in reverse (pinky to lip)
It works both ways which is more exciting that lighting a
mountaintop city in Switzerland....
I have a suspicion that my machine not only has applications
in space travel, but in high-energy physics as well.
So my next quest is to re-engineer Paul's voltage converter.
To maximize its amplification power.
Then i'll Give you guys some test results when I'm done.
sm0ky2
I have this thing powering the lights in my lab right now
sm0ky2
I want to talk about the magnetic bucking coil capacitors
Found on the giant horseshoe magnets in front of the Testatika.
This can be done using a ring magnet, with coils on each side
And is more efficient.
Paul uses a fancy word like "electron cascade generator"
Mumbo jumbo, hoopla....
What that is is an inductive plate capacitor
Wherein the two outer plates are the only ones connected.
The internal plates are charged inductively.
With a ring magnet set-up coiled plate capacitors can be used
It doesn't have to sit in the magnetic field. But it is handy
For space and to keep the lead wires short
Each coil is connected to one side of the capacitor
And because of this, they have different potentials and currents
The bucking field acts like an HV transformer boosting it before
It goes through the voltage converter for down-conversion.
The primary of the bucking coil capacitor comes off the machines
primary capacitor (Leyden jar) the other side goes to the low side
of the plate capacitor.
The secondary comes off the high side of the cap, and leads to the
voltage converter.
This also has another very important effect::::
And please pay attention!
Electricity generated through atomic and molecular induction
Be it by a direct induction machine, an influence machine, or a friction machine
Is comparable  to "incoherent light".
It is non-polarized electricity.
It will travel in unintended paths base on its spin orientation and the properties
of its' surroundings.
The electricity we use is polarized electricity, comparable to "coherent light"
It stays on the current path we provide it.
The magnetic bucking coil capacitor polarizes the electricity.
If you Omit this device, you can still drop the voltage through the converter
and it will still perform like low voltage dc.
However, it will still spark and jump out of the circuit like static electricity
And will induce crazy static charges on anything close to the circuit.
You have to "tame" it.
