Utron research
Started by Cherryman, February 02, 2017, 06:25:58 AM
Cherryman
Quote from: sm0ky2 on February 06, 2017, 03:08:03 PM
The most important thing I got from Mr Carr's mathematics
Was the geometries involved, that almost all replicators seem to miss.
The inside geometry is perfectly spherical
The cone can vary, because a cone is always geometrically
"coherent" with it's sphere. By the law of cones and spheres.
Think of it like an electron 'lense'.
Which also has a reverse focal point at the center of
The sphere
That's why he places an importance on the plane
90-degrees to the vectoral
Along the junction of the two spheres/cones.
Miss this and you are just spinning a cone shaped coil
I know, not missed by me.   : )  Be patient.
I know those texts out of my mind ; )
Thats why mine is hollow in the first place.
I'm going in small steps
Here is an update:
Testing the HV AC switching of the different half.
& Got Zapped !! : )
But it works!    Got some good switching going on, time to seal it up!
https://www.youtube.com/watch?v=UqQqTEm2NF8
Cherryman
Essentially the Utron will be a planet in space
The magnetic field is the Sun.
Question:
When i take in mind the cyclotron, then the magnetic field should be in line with the two halfs.
But when i take in mind the Sun and planets.. then it should be 90 degrees turned.
I think I have the answer.  Coil should be vertical in this case.
And some spark fun: http://www.youtube.com/watch?v=e4TrwBUSVnM
sm0ky2
Looks like you are heading in the right direction
What you have represents a single 'loop' of a coil
If you were to use coated magnet-wire and make
Many loops around the cone. Then make the inside
A sphere.
Current through the coils would produce a magnetic
Dipole one end being north, the other south
The center line where the two halves join
Is the perpendicular dielectric inertial plane.
The magnetic field is very intense at the tips.
It is the entire field of the coil, condensed to a small
Space.
The strength  of the magnetic field can reach far greater
magnitudes than expected from the same # of turns and
length of wire using a normal coil.
It's like electromagnetic 'neos' or whatever you want to call it.
Stronger field, smaller physical magnet. (At the tip)
The electrostatic energy is stored on metal plates (capacitors)
The magnetic energy is what rotates the main u-tron.
The magnetic field in the center (focal point of the sphere)
is purely in the electric vector. A charge at this point experiences
a force 90-degrees to the magnetic vector.
In the same way that electric current produced a magnetic field
90-degrees to itself.
The "air" inside ionizes and provides more than enough potential
to keep the charge flowing. But even in the absence of air (vacuum)
The very metal itself will induce charges because of the (0-point) charge
at the sphere's focal point.
When the main u-tron is set up properly, placing a current across the coils
It will begin to rotate in the same manner as any magnetic motor.
This creates a relative motion between any point around the center-line
of the sphere, and the charge. Thereby causing induction.
This is the main charging source of the device.
Your power supply
This is then converted back to charge the coils.
As the device spins up, current is induced through the coils in the smaller
U-trons around the outside.
The reason they are at the angle they are at is to provide an upward
rotational inertia to the craft. Which can be controlled by switching
the smaller U-trons to give control and direction.
These are your "steering wheels"
The small electrostatic energy they harvest is cycled back through
the entire assembly.
Hope that helps, if you have any ?'s I'll be glad to try and answer them.
sm0ky2
Don't forget to teather your UFO before you fully test it
We don't want another Searl incident
sm0ky2
Oh one more thing
Don't coil directly to the cone.
It's a step-geometry
Square- like legos or old nintendo
The frame of the cone coil doesn't
have to be part of the sphere
It's easier to have the two half spheres
Then use a non-conductive step-cone frame
to put the coil on.
You have to figure out your pitch and how many
steps there will be, how many turns per step, etc.
This is where I veer off, our knowledge of conical coils
is far more advanced than was Mr. Carr's, and that
discussion would be off topic, more applicable to
the subject of improving a working design.
We need to get one working first.
