re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
Quote from: seychelles on December 09, 2021, 08:23:06 AM
BUONGIORNO COME STAI.
https://www.youtube.com/watch?v=jiAZF0pMfyA
Bene ! Salute !
https://www.youtube.com/watch?v=YLNLePqVaQU&t=310sdispositivo gravi centrifugo per la produzione di energia elettrica
Comments
    David Davids    vor 2 Jahren   some info.     at 1:15, the  input force  mechanism, at left, has been correctly conceived; but poorly executed.    in it, reduction-MA  is converted to  INHERENT MA; in the large-radius wheel.     power is, correctly, taken off at a radius that is  smaller than the radius at which at which force was applied.   Mechanical Advantage.      THEN,  the   rotary output force is, stoopidly,  converted to  Reciprocating  motion.     ultimately, this machine does  Nothing.     there is  NO  energy gain in the  secondary mechanism;  in fact, the asymmetrical orbiting mass   is  acting  as a    governor/speed limiter.        any attempt to utilize gravity to achieve an energy gain, Will fail.     why is this true.       any apparent  energy gain on the 'downhill-side'  is ALWAYS  offset, by the Energy Required  to  OVERCOME  gravity, on the 'uphill-side'.     if interested, review my   ou- via-MA    research.      googletranslate        governor  https://www.youtube.com/channel/UCNSWIWz7trnMo4Wdbug0j9A/videos
Best greeting to Seychelles their fishermans,in search of Excellence, ::) , or nice mermaid/-s  !
Adeus
OCWL
Floor
@ seychelles
A real work of art
     and
         an amazing investment of time and materials !
But it looks like the generator / motor is powering it.
There is no principle, of which I am aware, and by which this machine
can operate otherwise.
   regards
       floor
seychelles
FAIRLY SIMILAR TO MR SKINNER GRAVITY MACHINE BUT IN REVERSE ROUND
ABOUT WAY.
sm0ky2
Quote from: Floor on December 09, 2021, 10:27:24 AM
@ seychelles
A real work of art
     and
   regards
       floor
Screwdriver pointed up, box wrench one end on the screwdriver
Tilt the screwdriver slightly one way then back the other.
Just a tiny bit, small small force required, each direction
get the timing right, you will feel it take off.
a small rodent could operate this
But get too close the wrench will take your face off
You're creating a situation of constant gravitational acceleration,
by tilting the axis of rotation.
depending on where you place your fulcrum,
the energy required to tilt can be less than the change in potential energy
Another example is a small child moving a 3000lb barell of water.
Tilt it on its' edge and spin it, the barell moves itself.
