SGWN Generator 300 KW
Started by franco malgarini, February 04, 2017, 09:51:19 AM
sm0ky2
That could work, though I don't know that the
Generator alone would get back enough to spin
Up the gyro again.
If we knew where it would stop
We could catch the weight when it flopped back down.
And the maniac in the long self-convoluting webpage
Is correct. I'm not sure why he has so much trouble with math
There are rotational situations where, in order for momentum
to be conserved, certain inertial energies are hard to explain.
If you think in terms of "equal and opposite reaction" to an
Applied Force - you could relate it to a glass jar under pressure.
A light tap from a tiny sharp object relates to an an explosion of
released potential energy.
The same can occur when a force is applied to a rotating object.
Angular momentum is like a battery. Fly wheels have been used for
Centuries to store rotational energy.
When an applied force causes the gyro to change its dimensional
plane of rotation, angular momentum is transferred to another plane.
This change of planes can be of the order of a plank length in magnitude
A force will occur at an alternate plane at each incremental change.
In practice, gyros are precessed in large increments we can observe.
And we restrict their motion to the normal 90-degree planes.
There are in reality a countably infinite number of planes.
Rotational forces occur along all of them.
So we must think in terms of a three dimensional force.
Equal and opposite to a point mass moving at the circumference
Of the spinning gyro.
Each point of mass creates its own opposing force to the applied force.
And by following a number of points around the wheel we can estimate
The path of the average force applied to any number of axial domains.
A gyroscope with infinite gimbals, one for every conceivable plane.
Then we could see the true reflection of the force we apply.
I hope I didn't complicate it by trying to simplify the explanation
The device in the patent is valid but I think the principal should be
Improved on, in terms of harnessing all possible energy until the
Gyro stops.
That would give a direct comparison of input to output.
What it took to spin it up, vs what we get out of it.
sm0ky2
These planes of rotation are universal
They extend through space and time
Allowing for curvature over great distances
Or intense energy densities
But at small distances, those humanly obtainable
The planes can be considered linear
As the earth rotates and orbits through space
And coincidentally the solar system and galaxy doing
The same
The plane of rotation of the gyro changes.
Even if it's physical angle to a point on Earth's surface
Does not change.
Precessional forces still occur.
The primary observable force is caused by our 24-hr rotation
More distant astronomical events take longer times to occur
Thus the change in planes takes place more slowly
An earth based gyroscopic precession is not only possible
It is inevitable
If you try to keep the gyro perfectly vertical and spinning for 24 hrs
The energy it takes to keep the gyro vertical
Is the energy output of the rotational system.
sm0ky2
Gravitational based gyroscopic precession is more of
A one-directional event than a cyclical one.
The force applied by gravity is always down.
The reactive force of the gyro is a factor of the rotational
velocity of a point mass at the circumference of the gyro
With an applied force accelerating it at 9.8ms/s.
If not restricted, the center of mass will lower and
Precession will occur at a ratio relative to the drop in height.
If restricted in a particular dimension, the center of mass
Will raise in height, and the same will hold true.
Contrary to the standard scientific description of this
Gravity has nothing to do with it. Other than applying the
acceleration force.
The reactive force of the gyro is in a vector that leads to
The center of rotating mass to be perpendicular to its'
Support axis. Regardless of where that axis is in space
Or within a gravitational potential well.
Vertical gyro can go horizontal, or a horizontal gyro can go
vertical. It doesn't have to be 90-degrees we just do that
to mask certain effects from public view. Not "we" as in us
But "we" as humans have a tendency to keep secrets from
the general public, by hiding them in plain sight or masking
them into obscurity by an overwhelming amount of useless
information. Knowledge is power. If we all had equal knowledge
Who would be in charge?
I suppose if we wanted to we could precess a heavy gyro in
the vertical plane like turning the standard example 90-degrees
The gyro doesn't care about gravity, it's no different than me
Pushing my finger on it to cause the precession.
What gravity does is provide a force in one vector
Regardless of which way the gyro is facing
Internally the gyro remains the same, but from our
perspective it could be used as an advantage.
gyros can produce an external force in response to
An applied force, a gravitational force, or a rotational
force (such as the earth rotating or a gyro on the surface
          of a rotating sphere or ring)
There may be other ways to apply a desired force, via
magnetism or electromagnetism, static electric attraction
or repulsion, or other things.
When we coordinate restricted multi-axial precession,
One reactive force, caused by a change in rotational plane,
Can result in a change in planes. This causes another
reactive force in another plane, and so on.
sm0ky2
The way we define our current geometrical theory
A circle is divided into 360-degrees.
For the simplification of discussion I will use the
Current Model. Not a more advanced model, so as
To avoid incomprehendable confusion.
If a circular motion represents 360-degrees, each of
these degrees is associated with a plane of rotation
Perpendicular to an axis. Thereby, an axis 90-degrees
to the first, has also 360-plane associated with it.
The same is said about the 3rd axis, that is 90-degrees
to both of those.
That is 360 x 360 x 360 = 46,656,000 possible planes
Of rotation that a gyro can exist on. (current model)
If we allowed 46.656M degrees of freedom
Our processing gyro would begin to resemble a proton.
The external forces of which are the integration of the Euler
mechanism, and are identical to the works of Feynman.
sm0ky2
I don't know how we would physically attach 46M gimbals.......
