Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
wistiti
Ok, Thank you for the reply!
As i see it you only have one layer of output coil... do im right? Maybe much more length/turn of the secondary is better... Anyway i will share my results as soon as i have the time to play with it.
Dog-One
Quote from: wistiti on April 25, 2017, 03:33:54 PM
Yes, single layer on everything.
There's a lot of variables at play here.  It's standard engineering optimization.  One has
to pick what to improve to make the overall system performance the best they can given
the restrictions of the interacting variables.  I didn't do any of that.  I only put the concept
into physical form to see it manifest itself, which it does.  The lamp glows, connected to
a broken coil that has an impedance of infinity.  My 40+ years of electronics says this
isn't normal behavior.  So with a few new tools in my toolbox, lets see what can be done
with fewer restrictions.
Dog-One
As you can see in the scopeshot below, sparks happen at about 73Hz where the
coil ring-down (resonant) is around 86kHz.  Voltage is off the scale--I'm surprised
I haven't smoked my scope with only a 10x probe setting.  Good thing this type
of electrical energy carries no current with it.
What's really amazing is thinking in terms of duty cycle.  The impulse lasts maybe
30us with a duration between pulses of 14 ms, giving us a duty cycle of ~ 0.3%
and yet it still makes the lamp glow with no resonant rise at all.  Pretty amazing
if you ask me.
Jack Noskills
dogone, great that you have working setup at your hands. Fun times ahead.
You can increase output power by using the dual output feature. Move the unconnected ends close to each other so that you get the white spark. I did not test this serially but it should work. Most likely the voltage waveform you showed in the scope remains unchanged.
Coil ringdown occurs at 86 kHz, does this frequency change if core is removed ? Is the ringdown time longer without core ?[size=78%] [/size]
Can you pulse this at resonant frequency with signal generator (no capacitor spark needed) ? Could be that longer primary coil is needed when there is no capacitor to boost the pulse. But nature will take care of it in the form of back-EMF when longer primary coil is used.
woopy
Hi all
just a test with a Bug zapper 3 volts on my EASTER COIL and a LED 220 volt
No claim here simply interesting results
good night at all
https://youtu.be/AXGHWdYDYO0
Laurent
