Thanks to ALL for your help!!
A video on the over unity of series to parallel recharging.
Started by spacecowboy, February 09, 2017, 05:58:14 PM
spacecowboy
Made a video with some projects any laymen can perform if they are into researching over unity through recharging batteries. https://www.youtube.com/watch?v=VTA7a9l7Ifo
spacecowboy
The reason for this is both positive and negative. Turns out I had made some mistakes, but I was not wrong in everything. Given some conversation I had with a commenter on my youtube video page. Seems Seems my commenter and I were both right and wrong on over unity strangely. I was wrong about adding more parallel batteries to be recharged thinking that would equal over unity, it only equaled a less of a recharge there on those batteries. However by sticking to only 2 batteries in series to be used to run the motor and also that recharging only 2 other batteries in parallel this turned out to be correct and works well. My commenter said the only way to be sure was to run the motor by itself on just the two AA batteries and see how long the motor ran, and then compare that against how long the motor ran as the whole setup also recharged the two parallel batteries. Turns out that even when I run the motor alone on the two Fully recharged AA batteries in series it runs around 14 hours, which is the same the motor runs when the setup is recharging the 2 batteries in parallel. Plus I can then swap the recharged parallel batteries with the then two drained series batteries at the end of the experiment, and get the motor to run an additional 9 hours. So there is still progress here, but I will remake these videos again getting ti all straight because as they are now I was mistaken a bit. So again they are now listed in my unlisted youtube video section.
