Leedskalnin's Perpetual Motion Holder in Electic form
Started by sm0ky2, February 24, 2017, 11:16:20 AM
sm0ky2
Back to the topic
The royal society article describes a method of locking the PMH
Using a permanent magnet rather than electric current.
This proves that the effect is not solely electrical in nature.
But can be purely magnetic.
We know through galvanic degradation that there exists
electrical potentials within the metal. but we have no
point of reference to measure their magnitude.
We know that the magnetic field is inverted or contracted.
The release of which, causes a field expansion, rather than a
field collapse.
This is conceptually the inverse of a field collapse, when the
magnetic circuit is broken.
Due to the interrelated nature of the magnetic and electric
components of electromagnetism - it stands to reason that
a circuit of electrical nature can be made to perform this action.
I propose that an electrical conductor of paramagnetic material
be fashioned internally to the center of the pmh
To act as a 'wire' placed in parallel path of the magnetic current.
Around this shall be placed a copper wire of very thin, coated or insulated
coils, of several turns.
This cored coil then be inserted into a groove in the middle of the
PMH material.
Holes be drilled or grooved so as to exit the copper wires from the device.
When magnetized or "locked", the PMH as well as the core of the electric coil
will conduct a perpetual magnetic current.
And if there is any fluctuation or change in magnetism internally
We should be able to detect it on the coil.
Such a test, if successful, would warrant construction of a very large PMH
pomodoro
Isn't it the alignment of electron spins that causes ferromagnetism?  Its not a perpetual current
Searcher1o1
If you wound coils on a toroid coil form like the pmh and pulsed them with dc would you get transformer action between the coils.
Would it be femf
pix
There is no mystery in Leedskalnin's Perpetual Motion Holder.
It exploits simple phenomena of soft magnetic materials HYSTERESIS.
Soft iron once magnetized  it keeps domains aligned, and as it is in closed loop - this magnetism keeps the steel bar attached to "U" bar.
You need to insert some energy to destroy domains aligment and align them in opposite side.
That's why every transformer has energy loses due to hysteresis.
Regards,
Pix
