A Simple Question About TPU Replication Attempts
Started by Eighthman, March 10, 2017, 12:17:11 PM
Turbo
Quote from: pix on March 18, 2017, 11:24:56 AM
Ladies and Gentelmans,
Here it is.
US3085189
Regards,
Pix
OMG you really found it !
Now we can all start building TPU's and save the planet.
Thank you so much !
Vortex1
Here it is.
US3085189
Regards,
Pix
Thanks for the patent PIX, it does show some interesting ideas, if it really works.
High points that seem to correlate somewhat with the TPU are:
Rectification (DC output) due to unidirectional motion of electrons in a gas, metal lattice or air. (the big one)
Use of a transmission line and travelling wave.
Acceleration of electrons close to the wave velocity (also big)
There is more but I guess we will have to build it and test it. Should not be that difficult. Same for the NMR stuff.
Regarding the NMR stuff, some folks use a slowly ramping DC current sawtooth or triangle wave for the bias coils and fixed frequency gated RF for the main coils in an attempt to slowly sweep through the range of the  NMR sweet spot (largest return echo).
This because NMR devices are very high Q and require precise frequency control as well as  gauss control and it is not that easy to hit the target combination.
pix
Quote from: Vortex1 on March 18, 2017, 03:28:27 PM
There is more:
1.Electrons drag, resulting from travelling wave , is enchancing travelling wave ( in SM words "it feeds itself')
2."Squeezing of the garden hose" analogy.
There is another patent, from 1890-tens, very similiar setup.
SM did used this patent, that's why guys from Atomic Energy Commision did warned him and shut up. This has been mentioned in one of Mannix interwiew with SM.
Anyway.
Everybody, please be welcome to explore what I just revealed.
Regards,
Pix.
pix
Quote from: Turbo on March 18, 2017, 03:04:21 PM
Thank you so much !
You are welcome.
Regards,
Pix
Vortex1
When I first skimmed the patent, I thought well, close, but no cigar, SM did not use gas tubes.
On a more thorough read, I can see that this is a very good find and good fit for the TPU as it shows that the travelling wave can effect (drag) the electrons in a solid metallic conductor or semiconductor (the collector) so a gas tube is not necessarily needed.
There are many other statements in the patent that make it a very good TPU fit if it works as claimed.
If you have any related patents, by all means do post them. Meanwhile I will search the citations of the patent.
Thanks again
