Simple Experiment: Extraction of Energy from Permanent Magnets
Started by dieter, March 13, 2017, 10:48:44 PM
dieter
Can permanent magnets be used as an energy source?
According to accepted beliefs in established science, permanent magnets can only convert energy, but are not an energy source by their own.
But there are certain problems with this theory. Strange seems the fact, that very simple experiments obviously do not obey the laws of physics and yet are completely ignored by mainstream science.
One of these experiments that everybody can do at home I will now present to you. It consists of a coreless coil, about 100 turns, a 9V battery and a permanent magnet. Arrange the parts, so when you connect the battery to the coil for a brief moment, the coil will be repelled by the fixed permanent magnet. Measure how far the coil was repelled.
I am quite sure there are formulas that explicitely show how and why the coil went that far, solely based on the electric current consumption from the battery. Seemingly, that's all nice and fine.
Now replace the permanent magnet by a much bigger, stronger permanent magnet. Repeat the exact same test, with the same DC pulse to the coil. This time the coil is pushed much further away than before.
How can this be? We used the same amount of input energy from the battery, but the output as a repelling force has increased. Where does the additional energy come from, if not from the permanent magnet?
In fact, it is stupidly simple. Total force= force of permanent magnet + force of coil.
Basicly, this is exactly what we have been searching for for so long time. A way to turn on and off a permanent magnet. Actually, we turn on and off only whether the coil is reacting to the magnet or not. But the effect is the same.
Conclusions:
By increasing the strength of the permanent magnets, less energy is required by the coils to maintain the same torque.
By infinitely increasing the strength of the magnets, the coils energy requirement would decrease infinitely, while maintaining the same torque.
By infinitely increasing the strength of the magnets, the torque would increase infinitely, therefor there is no linear relation between DC coil pulse and motor torque.
It must be possible to increase the strength of the magnets up to a point, at which the torque delivers enough energy to power an (inductively isolated) conventional generator, which then powers the coil pulses. Such a device would clearly violate a bunch of laws.
Applications
Back in the 19th century magnets were weak and expensive. The introduction of the selfexciting generator without permanent magnets lowered production costs greatly. Mechanical input energy was cheap. So permanent magnet motors and generators became widely obsolete.
Today we have strong Neodymium magnets, it should be possible to obtain considerable amount of torque even with a small motor. Although a big magnet with 1000 pound pull costs maybe 2000$, smaller magnets are much cheaper and can be stacked to increase their strength.
Right now this whole thing sounds too easy and too good to be true. All I can say is I made a test, as described above, with 3 magnets: a tiny Neo, about 5mm x 3mm, a medium size Neo about 5mm x 30mm, and a large stack of 4mm Neo disks, in all about 10mm x 70mm.
Coil was 0.5mm average diameter about 20mm, height about 10mm. No core.
With the tiny Neo the coil barely fell to the side.
With the medium Neo it flew maybe 80mm.
With the large Neo stack it fulminantly flew about 200mm, but was then stopped by the wire connections.
Could it really be that simple?
The future
Permanent magnets have their limits. However, in space temperature is near 0 deg. Kelvin resulting in superconductivity, which would increase the efficiency by several magnitudes. The resulting Free Energy could be used to power greenhouse spacestations and spaceships.
But even simple "earthbound" applications may exhibit very interesting results.
dieter
I did the same test with a cap instead of the battery, 2200uF at 7.3 V. Same results. Coil is lossy, due to low dc resistance of 6 Ohm, but still.
OscarMeyer
Quote from: dieter on March 13, 2017, 10:48:44 PM
Conclusions:
Applications
The future
Now don't take this the wrong way because I admire people who actually build things and try new ideas out in the physical.
The above having been said, the error in your experiment was the ACCURATE measurement of the wattage used in each repulsion test of different magnets of different strengths.  The ones that moved the farthest used more total wattage from your battery.  Yes, the voltage may have been 9VDC in each case, but the current was much higher due to the higher inductive force with the more powerful magnets.
What sometimes helps inventors to understand magnets is to view them as springs.  A spring can repel objects and a spring can also keep objects together making them difficult to separate as well.  Can a spring motor work?  Well clocks and watches use springs to power them, but they will always require rewinding, so the energy cannot be perpetual.  It is important to understand that a magnet motor that spins forever and generates excess energy is pretty much the same as creating a spring powered motor that never needs winding.
dieter
Thanks for your interest. I did the same with a cap, the results where the same. The amount of energy available for a short pulse was the same for all tests, in watt, or joule.
Although your explanation would rescue the law of energy conservation, I think you're wrong here. The decreasing fieldstrength induces an attractive superimposition in the coil, which works against the repelling pulse, therefor increases the resistance of the coil. Even tho, this should lower the repelling force, the observation remains as described.
forest
I agree with you.The problem as always is wrong interpretation of physic laws. I think that any object sitting on the table is working continuously against gravity (the molecular forces repel the object from the table). Magnet hanging on fridge is also doing work and energy is taken from vacuum, because magnetic field is "broken symmetry of vacuum"
Magnetic field and energy is one and the same.
