Thanks to ALL for your help!!
A Solid State DC-to-DC converter
Started by teslonian, March 17, 2017, 06:13:37 PM
e2matrix
Hi Gyula,   Thanks for commenting and showing the circuit on this.   I think you are right.   But for less than $5 to buy this little converter which  I have other uses for I'll give it a test and will try it with a battery.  Obviously if it is overunity as much as debunkified says it would self charge a battery.   I won't hold my breath for that to happen but it's an easy test.   Efficiency claimed in some ads for this list a maximum of 92% which of course is a far short of 1800+ %.
rakarskiy
This guy from Ukraine built this device. The author explains:
QuoteMany argue that it is impossible to extract energy from the magnetic field. He does not do the work. I do not agree with this, because I was practically able to confirm the opposite (through experiments). If the magnet does not perform visible work, this does not mean that it does not have the potential for energy that can be extracted with the right approach. Therefore, I definitely determined that the influence of other forces (electrical waves, light, radiation, etc.) does not play a role in the experiments, which confirms the generation of energy from the magnet.
The dependence of the force of the magnet on the generated energy is clearly seen.
The spiral is the main component of the generator, which is created by the alloy of many elements. The electrical circuit is a converter.
By experiments, the dependence of the size of the magnet, its force (magnetic flux, permeability, intensity and induction) on the amount of energy produced is calculated.
Every year the generator loses 2% of capacity, which will lead to a loss of 50% in 25 years.
However, even after 50 years, the power will not fall to zero, because The output will come from the Earth's magnetic field (though not essential).
In the future, the task is to select the most optimal composition of the spiral and the characteristics of the magnet, which would increase the life of several times.
https://youtu.be/AiBNnDSXHbM
https://youtu.be/QFg7W9fVkgE
https://youtu.be/MvZrK0e4c_U
https://youtu.be/3gIGMJL0pIA
Magluvin
I had dealt with this guy before on some of his vids.  Naturally if the output of the circuit is a voltage just above the input voltage, the output can supplement the input some, showing a lower input from the input. So is it just lowering the input compared to idle currents?
He does it all for the ad money.
Mags
gyulasun
Quote from: rakarskiy on March 21, 2017, 09:53:08 AM
This guy from Ukraine built this device. The author explains:https://youtu.be/AiBNnDSXHbM
Hello,
Are you aware of a forum where he disclosed the secret recipe for the exceptional material 'mixture' ?  I figure it is the billion dollar question...   8) if the setup shown is not a fake.
Thanks
Gyula
gyulasun
Quote from: Magluvin on March 21, 2017, 01:11:43 PM
Mags
Oh, for the ad money? I have not thought of it yet... in his case at least,   thanks.
Well, the amplitude of the feedback current influences the input current but I think the relationship is such that allowing higher feedback current increases, while a lower feedback current decreases the input current, I deduce this from his DMM and from his analog amper meter measurement data (see my reply #4).
I also commented last year two of his videos, one of them was this https://www.youtube.com/watch?v=Po_c3qnR088 where he experienced output power via a power MOSFET which was not fed with a battery or any power supply but its gate-source was pulsed from an 555 timer. So there was no anomaly.
Gyula
