The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
0 Members and 42 Guests are viewing this topic.
synchro1
Quote from: TinselKoala on April 18, 2017, 06:01:48 PM
I just love it when you refute your own nonsense yourself, with information you find when finally googling the terms you misuse so flagrantly.
Nowhere in those various equivalent expressions for the Henry does an expression for ELECTRICAL POWER exist. ELECTRICAL POWER is measured in WATTS, the units of which are Joules/second. You will note that I TOLD YOU several times earlier that the Henry can be expressed as Joules/ampere2, which DOES appear in that chain of equivalent expressions. If a "negative henry" is "equivalent" to "watt-hour" as you have repeatedly claimed.... since the watt-hour is an expression of ENERGY NOT POWER...  you once again are getting all tangled up with your own claims and the solid refutations from the material you yourself post.
@Tinselkoala.
What do you call an ampere second at one volt? Joseph Henry defines the H as The amount of inductance (Coiled wire) it would require to generate one volt by varying a current by one ampere per second across the inductor.
Definition of Watt Hour:
"A Watt Hour is a measure of electrical energy equivalent to a power consumption of one watt for one hour".
You falsely state that a "Watt Hour" is energy but not power, when the truth is it's equal to power!
You twist the other very valuable word to cause the kind of Gnomic mischief you're notorious for? Who can find a negative when it's past zero? Coupled with compulsive adolescent insults and abuse, snickering to yourself, through your schlag covered face.
synchro1
Times up: The ampere second at one volt is a "Watt Second". A watt second times seconds and minutes (60)x(60)= 3600 watt seconds=One "Watt Hour". That's equal to a consumption of one Watt for one hour. A "Watt Hour" equals 3600 Coulombs.
Electrical power input to an induction coil generates a magnetic field. The field force measured in a coil of 1 Henry with one watt hour of power stored in it's magnetic field equals 1 Tesla of magnetic flux density.
synchro1
@Tinselkoala,
You need to start with the "Magnetic Coulomb" law:
"In physics, the magnetic Coulomb law is the magnetic equivalent of the electric Coulomb law".
"The magnitude of the electrostatic force of attraction between two point charges is directly proportional to the product of the magnitudes of charges and inversely proportional to the square of the distance between them".
synchro1
@Tinselkoala,
Ponder on this:
"The unit for magnetic reluctance is inverse henry, H−1".
"Magnetic reluctance, or magnetic resistance, is a concept used in the analysis of magnetic circuits. It is analogous to resistance in an electrical circuit, but rather than dissipating electric energy it stores magnetic energy".
nelsonrochaa
Quote from: synchro1 on April 19, 2017, 07:13:14 AM
@Tinselkoala.
I think that exist a misunderstood or a fault of communication about this subject . Watt and Wh have different definitions .
A watt (W) is a unit of power, and power is the rate at which energy (joules) is produced or consumed in a second .
A watt-hour (Wh) is a unit of energy; it's a way to measure the amount of work performed or generated  in one hour
joules X time 3600S =Wh
watt-hours measure amounts of energy for the specific period of time of one hour, and watts measure rates of power at a moment in time.
Just to clarify
Nelson Rocha
