The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
evostars
Quote from: nelsonrochaa on September 06, 2018, 09:55:39 AM
Hi Evo,
Sorry i forget to mention the secondary coil L3, which is a pancake coil as well, to stack in the order L1 L2 L3 .
Does this mean,  in my additional drawing, L1 = L2 and l2 = L1  to keep the stack in the right order,
correct?
evostars
c3 c4 and c5 are probably 0.1 or 0.22uF 100v xicon greenies
hartiberlin
Hi Nelson,Many thanks for the circuit.
And then L3 is the output coil ?Then it makes much more sense...;)
Also is there a connection at the top where the diode goes to the Mosfet ?Is the diode cathode also  connected to the 2 caps there ?
What is the circuit doing ? Just oscilating and pumping energy into the L3 output coil ?Why is it then so efficient ? Because of the floating ground ?
evostars
it's a radiant circuit. a capacitor is overcharged with negative voltage than internally discharges, creating an impulse. this is the key.
it's all tuned.
Belfior
Quote from: evostars on September 07, 2018, 03:27:32 AM
it's all tuned.
I'm wondering if using the back-EMF is why devices like Moray's kept cold while running? If you used his device to power bulbs they were bright white. If you used the grid they were yellowish.
If the back-EMF takes energy from the ambient then it could be in a different form than what we create with dynamos. Like light is light, but then there is laser, UV etc
The beauty is that scientists agree the energy is there in the vacuum. It is the radiation from EVERY source. I think this is the "Ether". Then you create a situation that Nature wants to equalize. Then you don't need to figure out where the energy comes from or how. Nature will put it there. Like there is no energy in a battery. Then you connect the terminals and energy appears. This is so trivial to us, that we don't give it a second thought. The point being that the energy is not there, but it appears when Nature tries to equalize both levels
