The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
onepower
Belfior
QuoteI like Ivo's videos, because he is interesred in the same phenomena as I am. He creates an experiment and tries to make sense of the results. He just needs input from other experimenters like we all do. This input steers you hopefully towards real discoveries.
It may help to describe what radiant energy is and how to produce it from someone who has real experience with it.
My first real experience with radiant energy used a 100kV DC supply (Van de Graaff generator), a choke coil and an 8" stainless steel sphere. I found that if the DC supply discharged through a quenched spark gap into the choke and sphere. The sphere would make a pinging noise and eject physical matter from the surface as a super fine dust. When grounded plates were suspended nearby the plates became charged to a very high DC potential.
How can this be?... it is very simple. The supply discharges a massive number of free electrons across the spark gap in an extremely small time frame into the choke. The electron density is very high in the choke which pushes the electrons into the sphere in one big slug within a small time frame. This creates a high density wave of electrons travelling over the surface of the sphere. The drastic change in potential on the surface due to the very high charge density also causes physical material to be ejected from the surface because like charges repel. Opposite charges attract and like charges repel.
Think about it...
1)a material becomes highly charged within an extremely small time frame,
2)the charge density becomes so high so fast it starts tearing apart the surface of the material due to the massive repulsion forces,
3)Very small pieces of physical material which are highly charged are now repelled from the surface due to repulsion forces.
4)The ejected material carries the same high density of charges with it on it's surface which is why it charges anything it strikes.
5)We can now see a simple mechanism whereby large amounts of energy can be transferred through a space without a wire conductor. Understand each individual highly charged particle is a "conductor" of energy.
This is the mechanism Tesla used to produce radiant energy and create radiant matter. This is literally radiant matter as small pieces of matter ejected from a surface which carry a very high surface charge thus a great deal of energy with each piece of matter. Do you now understand why Tesla said the effect produced a "stinging sensation" which I have experienced as well?. It is very simple and is no different than a pith ball experiment where a little tin foil covered ball oscillates between a charged sphere and a grounded sphere transferring the surface charge or energy in the process. The process is identical and only the scale has changed, in effect my large highly charged sphere was simply ejecting a stream of very small highly charged pith balls. Obviously my sphere can be replaced with a single wire, a coil of wire or a metal plate so long as the effect remains.
My point here is on perspective, how could everyone misunderstand something so simple?, how could they miss something found in every high school textbook?, how could so many have such a poor understanding or misunderstanding of even the most basic principals of electrodynamics?. It all comes down to the fact that like charges and charged objects repel one another then progresses from there.
I'm not sure how or why everyone has managed to turn something relatively simple into such a god damn fiasco of false beliefs and misunderstanding however I do know we need to change what were doing. Stop over-complicating everything, understand the basics then build a logical process or sequence of events on it.
AlienGrey
onepower
TK
Your a HV guy, have you noticed these effects?.
I have found the effect I described is based on the following requirements:
1) The supply must be HV and preferably have a negative potential.
2) The supply should discharge the maximum energy in a minimum time frame with no reversal of the current.
3) The input is not AC it is DC and whatever energy enters the sphere through the spark gap is radiated with no arcs or sparks from the sphere which should be avoided.
You will know when it happens because the sphere will make a sharp "ping" noise on each discharge as an indication that the material has physically contracted and set the sphere itself into a material oscillation. If it does not oscillate then the rise in potential is too slow or the magnitude of the potential is too low. It's a sledge hammer effect, nail it as hard as you can as fast as you can with no reversal forcing energy to radiate.
This should sound familiar and I suspect Ed Gray based his technology on a similar effect. Nobody should think they can create an arc discharge from two electrodes at different potentials inside a copper cylinder and think the induced voltage on the copper cylinder can power a 50 hp motor... that is absurd. Induced by what, from where, by what means?, we have 100 years of experience with induction and it simply does not compute therefore it must be something else.
AlienGrey
