The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
evostars
Quote from: evostars on October 22, 2018, 02:42:44 PM
I'm still workimg on Nelson's radiamt circuit.
seems I was on the right track, but its all slightly different.
L2 is series resonant with C5
C4 is charged by the back emf/inductive spike from L1
C4 is discharging parallel over L2/C5 when the mosfet turns on again, giving the disruptive discharge.
The mosfet therefore needs to have a very small Rds.
L3 sees the kick of this capacitor discharge. Which is a radiant energy event.
I will keep working until it all more clear, and then its time for another youtube video.
I feel blessed for being able to make so much progress.
As I still dont understand fully how this works. I keep learning from my mistakes... So this info might be wrong... Ill have to make it work first before I share this kind of information.
Still doesnt work... but learning along the way
evostars
My new video about high side switching a coil.
This also explains the "earth" at the source of nelsons circuit.
still working to get it to work.
Have reached the disruptive discharge in L2!
https://youtu.be/Asa2RuubKWM
evostars
Belfior
Quote from: evostars on November 22, 2018, 01:53:45 PM
New video will premiere in one hour:
  https://youtu.be/MF1lVtAgzVM
I'm wondering is this your own version of the disruptive discharge, because I think how Tesla did it was he had a 25-30kV dynamo that fed large capacitors. He then discharged the cap over a spark into L1 and had a short secondary inside it. Spark was killed with 2 opposing magnets, so he could get single direction discharges without any back waves/sparks.
He is claimed to write that over 100microS pulses you could feel on your face even behind metal plates. Pulses under 100microS the effect was lost and you got other effects like cold breezes.
Are you pursuing getting that negative spike into L1 and to L2? Maybe it is obvious, but you have a lot of gear in the videos :)
evostars
Quote from: Belfior on November 22, 2018, 04:43:38 PM
The spike I show is from L2 (nelsons circuit) still working on it
