The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
evostars
I found out, the best way to impulse a bifilar coil, is to impulse it from both ends, one side positive impulse other side negative impulse, but simultaneously.
Nelson rocha's latest shared circuit does this.
It not only does that, but in the same coil that is impulsed, is also series resonance creating high currents.
the impulsed series resonant coil, is a primary.
The secondary, is inductive coupled, so sees the high currents. But is also in the radiant field induced by the impulses.
Without the current, resonance can easily be tuned into the secondary, as you will be able to see what you are doing on s scope. But the high current, prevents this... It seems to be tuned differently...
So with the current in the secondary, your tuning blind... adding capacitance until it resonates with the impulses of the primary.
When tuned, this could deliver voltage in a high current coil. in phase.
So far only theory...
only need to tune...
mzp
Hi,
I wrote special Audacity plugin to create AM pulsed freq. https://github.com/MichaelZP/SyntheticSecretSound
I can remake it for this project on requested suggestion
evostars can you please check, and show how signal and connection diagram should look?
Thank you
Michael
evostars
I have made a new video with extra info on the bifilar coil and the highside switch.
this is needed for my new circuit, that will be explained in the soon to be uploaded video
https://youtu.be/Y0TJ84Rbx6Q
AlienGrey
Quote from: evostars on March 30, 2017, 08:43:54 AM
some shout: The Earth is flat! you fools,  it has been proven! the earth is the center of the galaxy! you fools it has been proven.
clearly we live on the same earth,  and we now believe its a sphere (most of us).
maybe in the future we find out its a hollow sphere,  and we live in the inside.
What I'm trying to say,  is its all a matter of perspective.
you can see the electrons and atoms as particles, because it was proven,  as was the flat earth.
I never believed this to be true. all is light,  all is made of light fields and vortexes. particles are made up to under stand the complexity of the fields easier. but its only a trick,  that has its limitations. even the dielectric and magnetic fields are made of the same stuff. light.
please believe your own truth, which ever works best for you.
http://radio.offplanetmedia.net/2017/03/19/dr-shmuel-asher-nasas-first-major-disclosure-the-dome/
Well there ya go !
evostars
I made an advanced solid state hairpin circuit producing radiant power.
It is based on a high side switched coil (L1) producing a negative back EMF impulse.
This impulse is injected into a series resonant bifilar pancake coil (L2).
The – BEMF impulse, replaces the sparkgap.
This L2 coil also has a positive DC offset, charged by the – back EMF.
The L2 coil equals the stout bars in the hairpin circuit.
L2 is loose coupled (4,5cm) to L3 (bigger bifilar pancake coil) that is parallel resonant. So both L2 and L3 resonate on the same frequency. L2 is series resonant (low impedance, so impulse can pass to positive of power suppy, giving the L2 a kick) and L3 is parallel resonant (high impedance).
L3 is parallel loaded with a 28W 230V light bulb, that lights up brightly.
The current and voltage of L3 are in phase. This is rather unique, as it is 4,5 cm distanced from the series resonant L2 (current and voltage 90 degrees out of phase). Radiant power is produced.
Here is the link to the video explaining it all. All info that is needed for replication is included.
https://youtu.be/1Flj1i0zQ-8
Here is the link to the schematic:
https://imgur.com/a/sh1JOwE
