The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
stivep
Quote from: evostars on November 20, 2020, 06:40:08 PM
think what ever you want.
it's online in 1 hour and 21 minutes.
Goodnight
Why don't you make it public  if you showing it to the public any how?
what is your motivation?
Wesley
forest
by Longitudinal resonance I understand simply a resonant standing wave on antenna then the way to tap magnetic field without disturbing resonanceand yes - I believe it is perfectly possible
Hendershot or Hubbard or Amman brothers even famous Tesla car or even Kapanadze devices....and so on
stivep
Quote from: evostars on November 20, 2020, 04:35:45 AM
Video will be watchable from november 21 2020; 1:00 AM GMT
It shows my Radiant half bridge circuit. explained into detail, and working.
Longitudinal resonance and current amplification by impulses.
https://youtu.be/c2_rKc7sHGk
I only got to the minute 49:08 of your video and decided to comment  it till now.
I will watch it to the end.
___________________________________
I do thank you for this video and I  will specify why:
1. excellent quality.
2. absolutely  outstanding  in clarity .
3. smooth   like butter.
4. visual effects  and sound are precise and concise.
5. great  quality  of hardware :
a- good organized PCB
b- shockingly well done  and precise assembly
    as if it was German or Swiss presentation.
c- distinctive original simply beautiful.
d- good English  skills
But till that very minute 49:08,  your video is  in area
-of weirdness  beyond accepted region  of tolerated logical deviation from technical stand point and is far in its controversially on the negative side.
I feel fluttering in my chest every few minutes or so when listening to  your explanation.
-the quality of being strange and unusual doesn't make you less valuable .
It only  makes your video  immediately rejectful due to amount of  the nonsense you said there,
So yes you have got my attention from behind  of 3 firewalls...++.
I stopped watching, when you introduced the new cow or another holly cow to the video
  called by you:
- LMD Longitudinal Magneto Dielectric .
Unfortunately Eric Dollard was wrong and you are terribly, lacking  education in this area.
and yet  you are spreading nonsense to even less potent  viewers  of your video.
_____________________________________________
Preconclusion
Please note this is
not prejudice. and has nothing to do with connotations of intolerance, and  implies no  negative bias,
I admire your work on that video and time spend .
Wesley
stivep
Quote from: forest on November 21, 2020, 04:28:22 PM
standing wave on antenna then the way to tap magnetic field without disturbing resonance and yes
There is no such thing as "Longitudinal resonance" in quantum world.
Standing wave is present in the circuit between Tx along transmission line and Antenna acting as a load due to VSWR mismatch.
http://www.antenna-theory.com/definitions/vswr.php
The problem of all researchers is to look not at  circuit phenomena
but analyze  mechanism of energy transfer and  than
create circuit that  works with  that desired energy transfer process
till the energy is present at the output in the form of our convenience.
Wesley
forest
unfortunately I don't know radio engineering  much and here we must produce antenna which is totally different then normal radio - our purpose is to create standing wave with no EM radiation...basically what we have is HV HF tank circuit with low amps HV current and attached antenna with not radiating wave and with peaks of LARGE magnetic field as shown by many russian fellows
then it is not much different then ordinary generator - we fight the Lenz the Lorentz force and then we have what Tariel said = that way the clevery made secondary do not load primaryHubbard was a boy (19 years old ) interested in radio ,Amman brothers have some kind of radio transmitter and receiver working together probably generating beat frequency (two  antennas loaded with ball on top)
because magnetic field is sine qua non for generation of electricity it means magnetic field is source of electric energy !
