The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
0 Members and 41 Guests are viewing this topic.
A typical response from someone who makes outrageous claims that he cannot back up with actual evidence, when challenged to do so.
Coil current reversal when power is interrupted? Disproved by me and by TinMan and by hundreds of thousands of circuit designers who put flyback diodes across inductors, as well as by Faraday's Law of Induction. But Zephir still has not retracted his claim nor has he explained the LEDs lighting in TM's or my demonstrations, nor has he produced any experiment or demonstration of his own in an attempt to refute us.
Overunity is easy? And when Zephir is challenged to provide evidence, he posts links to Infinity SAV Team ! Why not Innova Tehno, or Veproject, or the Pakistani mo-gens, or even the guy who plugs his power strip into itself and then runs a lightbulb?  What is "easy" is to fool Zephir, apparently.
Falsely characterizing what I do and don't believe? Yes, please do put me on your Ignore List so you don't have to notice when you are soundly refuted over and over again when you make your false claims.
synchro1
Quote from: TinselKoala on April 10, 2017, 03:57:31 PM
@Tinselkoala,
You charlatans had me flummoxed with your cute double entendre a year and a half ago. I retreated to Energetic Forum as Allen Burgess and initiated a thread entitled "Flyback Current Reversal". We heard from lawrence Tsung who cleared the entire matter up with the term "Negative Current. It's high time you knocked the crap off. Everyone can find a minus sign on every analog amp meter. Negative current can travel in the same direction as positive current. Denying the existence of "Negative Current" as Citfa doe's (Negative Dose) is just a cheap con trick. When are you gonna grow up?
starcruiser
Quote from: TinselKoala on April 07, 2017, 02:08:07 PM
Wrong again! All real wires have resistance and ALL REAL CAPACITORS do too. Look up "ESR" wrt capacitors. For this claim of yours to be true you would have to have a capacitor with zero resistance and a connection with zero resistance, both impossible in reality, and the current on charge and discharge would be _infinite_, taking no time, which is what a vertical line means. Infinite slope! A change in charge over +no change in time+ !!!! Ridiculous on the face of it, as everyone _actually_ knows.
Good luck with that.
Anyone with a scope and the wit to use it can prove you wrong in fifteen minutes.
You want to keep moving goalposts and constructing your strawman arguments instead of admitting that you were wrong, go ahead. You'll wind up here just like you wound up at EF: nobody pays attention to you since they all know that you are full of yourself, you misrepresent and misunderstand and prevaricate, and you will never admit that you are wrong.
TK,
1st TC in either which is approx 63% of the capacitors charging or discharging capacity, it is fast to start and slows in either case (charge or discharge) the current curve is kind of opposite though.
Regards,
Carl
synchro1
Dr. Tsung went further and stated that "Negative Current" was the pathway to overunity. Everyone knows that TK's click of frauds are just paid sock puppets for the fossil fuel lobby.
Quote from: synchro1 on April 10, 2017, 05:08:59 PM
LOL   In Kirchhoff's Current Law all currents entering a node in a circuit must sum to zero.  The convention is that currents entering a node are denoted as positive currents and currents exiting a node are denoted as negative currents.  "Positive" or "negative" merely denote the direction of the current flow.  There is no such thing as "negative current" in the way I suspect some people might be thinking.
"The algebraic sum of all currents entering and exiting a node must equal zero"
"That is, if we assign a mathematical sign (polarity) to each current, denoting whether they enter (+) or exit (-) a node, we can add them together to arrive at a total of zero, guaranteed."
https://www.allaboutcircuits.com/textbook/direct-current/chpt-6/kirchhoffs-current-law-kcl/
So all of the fussing and flustering and fussbudgeting and the general spreading around of misery and drama and unhappiness and insults about this subject can now stop.
