The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
synchro1
@Tinselkoala,
Here's something to help:
1.- "The basic unit of measurement for inductance is called the Henry, ( H ) after Joseph Henry, but it also has the units of
Webers per Ampere ( 1 H = 1 Wb/A )".
1a.- "An ampere is a coulomb of charge per second".
2a.- "The weber /ˈweɪbər/ (symbol: Wb) is the SI unit of magnetic flux. A flux density of one Wb/m2 is one tesla".
synchro1
@Tinselkoala,
Still waiting for your reply. Here's more help:
A Kilowatt of power collected in a bank of storage batteries would accumulate into a given charge. An Ampere hour of power fed into an inductor would be stored in a magnetic flux field and add up to a charge.
Are you having some kind of meltdown synchro?
An Amp-hour is NOT A MEASURE OF POWER. An Amp-Hour is NOT A MEASURE OF CURRENT.
The Henry and the Tesla are NOT EQUIVALENT, even if you put a minus sign in front of the Henry.
It is very clear that your words mean whatever you think they mean when you use them, not what they ACTUALLY mean. And you change what you think they mean whenever you finally get around to looking up the words you use in some kind of dictionary.
Your own words:
QuoteAn Ampere hour of power fed into an inductor would be stored in a magnetic flux field and add up to a charge.
QuoteA negative Henry is the equivalent of one Tesla of magnetic strength. Both have positive values.
QuoteHow much magnetic strength will one ampere-hour of current generate in an inductor of one Henry of inductance?
Quote2.- One Tesla of magnetic strength in an inductor of one Henry of Inductance with one ampere-hour of current flowing through it reads as one negative Henry on the inductance meter. The minus sign indicates the level of magnetic strength. The inductance meter in the negative value acts as a gauss meter.
It is utterly impossible to have any kind of rational discussion with you because YOU DON'T KNOW WHAT YOU ARE TALKING ABOUT.
synchro1
Quote from: TinselKoala on April 14, 2017, 11:05:56 AM
Your own words:
@Tinselkoala,
What's the answer to the question I asked you; How much electrical power would it take to generate 1 Tesla of magnetic flux in an inductor coil of 1 Henry of measured inductance?
Quote from: synchro1 on April 13, 2017, 05:31:14 PM
More insulting and obnoxious abuse from a complete ignoramus named TK:
Preserved this insulting and obnoxious abuse from the champion of obnoxious abuse Synchro1.
