Home Nucler Reactor class 180
Started by NKE, March 25, 2017, 09:06:06 AM
ramset
The test device doesn't have to go anywhere ,can all stay there
would just need to verify your claim ?
what is your claim ? 7500 watts to heat a 100 square meter home ?
how Hot in house
how cold outside of house ?
what kind of house [grass ,brick wood ,stone?
what does 3hrs mean ??
would be better to measure one very well insulated drum of water  start temp...stop temp "speed to heat"
ambient temp etc etc
and a graph ??
you must already have this data ?
respectfully
Chet K
Thanks Grandma
pix
Quote from: NKE on April 05, 2017, 01:30:05 PM
7.5 kW (10.5 kW heat power) model heats 320 sqm total in 10 hrs of work.
But to do this needs 6 tanks, 300 L each (1.800 L total).
how Hot in house 20 C
how cold outside of house ? -15 C
what kind of house: old brick type with 12 cm insulation
what does 3hrs mean: for 100 sqm heat to accumulate
Crap
MasterPlaster
Wow this looks like the real deal. Even our resident trolls are not bothering with this thread.
Perhaps they are recognizing one of their own.
Golly, a nearly six year old, 20 second video showing the same thing you are talking about in this thread! I'm like totally convinced !
ramset
Well
Now it would be VERY easy to do a simple test ,heat a 45gallon drum of water [if you need bigger OK]
you will need
a big cardboard Box [not completely necessary if OU is obvious
the Drum
two or three thermometers [only two for basic test [without measuring motor heat to room]
a resistor [to measure power input to motor]
and a stop watch [time to heat
will you do this ?
we can go over the test protocols [would be a very good idea]
you'll be elevated to a deity if you break the OU boundary for energy required to heat water/
very simple and quick test
and I WILL RUN A CONTROL TEST HERE WITH A RESISTIVE HEATER AND YOUR INPUT POWER.
YOU WANNA "RACE"......? INPUT POWER AND TIME TO HEAT !!
I TRULY HOPE YOU WIN..........
Honestly to be fare if we race we'll need yout whole rig in a box since your motor is adding heat too
I will run my settup inside the same size box here [to be fare]
and then the number crunchers/metrologists can compare everything [the water part should show it all tho
yes ??
No ??
respectfully
Chet K
Thanks Grandma
