Home Nucler Reactor class 180
Started by NKE, March 25, 2017, 09:06:06 AM
Floor
Floor
@Ramset
Quote from ramset
"I can usually work my way thru a post from almost anybody here ,and honestly ,I understand your comment"
END Quote
                 Reading might help you work through those posts.....
                                    because
                No, honestly, you did not understand.
                You understood NOTHING. I'll repeat that for you.
                              (Quote from ramset  "[incase you missed the first nothing" END quote)
Quote from ramset
"HOWEVER
you have wires crossed on Peter's forum [over unity research
he sells Nothing"
END Quote
                         No it is you who has have crossed the wrong wires this time.
                        Are you an idiot ?  I did not say he did on his forum. I said his book
                        was sold on this forum.
Now please don't next,  say that I called you an idiot.  It may seem to you, that I
have implied that, as it seems, you have implied this of me, when you said
                        "NOTHING>>>>NOTHING [incase you missed the first nothing".
But I did not call you an idiot.  No need for that.
Try to be a little more honest / use less subterfuge  next time you respond to me please.
I don't respect the lack of honesty, nor subterfuge.
ramset
Floor
Sorry I had a mental block on your handle and your posting was completely out of character
for the man I am use to reading here [who demands respect of his threads
That and the fact I Had detached retina surgery last month and my mind is very worried and distracted about the future.
a PM would have been much better ??
I honestly had you confused with another member [eastern European]
and that is the truth  :-[
why did you come so aggressively here ?
did I ever treat you poorly somewhere ... anywhere ??
IMO
you are a champion of open source research and Peter is a champion too
for supporting all of Overunityresearch from his own pocket ..
please show me where Peter sells  anything at his forum
or links to any products?
or advertises to help pay for the forum??
I honestly am completely unaware of this ??
this has taken a big turn [for me]  now that I know who you are
I apologize regardless for my behavior above...[when I thought you were some one else who never posted an experiment here .
Chet K
Thanks Grandma
citfta
With only a very few exceptions cavitation is something to be avoided.  It is very harmful to the pumping mechanism.  It also creates a lot of noise and high loads on the driving force.
I was called to look at a motor in our plating shop that was kicking out the overload breakers.  The motor was new and was driving a new pump that was pumping acid.  Some engineer that didn't know what he was doing had specified the same size pipe for the inlet as the outlet.  On all centrifugal pumps the inlet pipe should be larger than the outlet pipe to allow the fluid to flow at a slower speed coming in than going out.  Cavitation is caused by trying to pump out the liquid faster than it can come it.
In addition to kicking out the breakers the pump was making a loud rumbling noise that could be heard from several feet away.  I recognized the rumbling as soon as I heard it.  To try and stop the noise someone had turned back the intake valve restricting the intake even more.  This only caused more noise and kicked the breaker even faster.  I checked the current draw and it was about twice what the oveload breakers were rated for.  I opened the intake valve all the way and started closing the discharge valve.  When I had closed the discharge a small amount the noise immediately stopped.  When I then checked the current draw it was well below the overload breakers rating.
Here is an engineering article about cavitation:
http://engineering.wikia.com/wiki/Cavitation
Respectfully,
Carroll
