Free Energy Transformer 300w AC
Started by justawatt, March 26, 2017, 05:45:27 AM
starcruiser
Quote from: dieter on March 27, 2017, 02:25:58 PM
@Starcruiser,
thanks for the diagram. Did you see L1+L2 in the Vid? What is the purpose of the fan?
Also, aren't they MOTs? That would be 1:5, stepdown from 240 to 48 ac, rectified maybe 65 dc, for the 12v fan?
@Dieter, In the video he soldered this across the small cap, is was a torrid style coil, he did this for each leg.
It was 4 large AC capacitors and 4 smaller ones with a small inductor (torrid) across 2 of them. See below pix.
the Video showed the fan with several diodes (hard to make out) that looked to be a full wave bridge setup. and went across the 2 outer wires. See pix of Fan Diodes below
The transformer was center tapped so I inferred it was perhaps an 18vac secondary? maybe a 12Vac?
The video showed a small volt meter that was at 230 at the start and was down to around 120 ish near the end of the video before he killed it. See pix of voltmeter start and end volts.
Really need to work out the transformers inductance and calculate the required capacitance to get a 50 or 60hz resonance, as the transformers are optimized for the line rate of the power company.
As far as the fan goes, not really sure perhaps a load to keep the voltage in check? I am not sure they are MOT's to be honest
Regards,
Carl
dieter
They looked like MOTs to me, but MOTs have no center tap, just a ~3 turn strange coil between primary and secondary, also the secindary 1200 vac output is connected to the core at one end of the coil.
However in a country using 120vac grid, the 120 to 1200vac MOT could be used reversely: 120 to 12 vac. EDIT on second look they may not be MOTs, even tho almost as big as MOTs, but with uncommon plastic bobbins.
A lot of guessing there.
kr
penno64
AlienGrey
Quote from: dieter on March 28, 2017, 03:19:39 PM
kr
MIOT's ;)  look again they have been re wound, and you need at least 36v Volts to do that sort of thing with resonance, now find out what size the caps are to alter the phase.
