Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
hartiberlin
Now here are also the voltage,  current and coil flux density curves
with the circuits.
Enjoy !
allcanadian
Correct me if Im wrong but your LED is forward biased like a diode, it is a light emitting diode therefore no current can flow through it in a reverse direction. So if the switch is open and the current/voltage cannot flow through the LED(diode) it has no reverse path? I have been designing and testing electronic circuits for 30 years so Im fairly certain this won't work as depicted.
hartiberlin
Yes, in case 1 there will be no LED light as there will flow no
current through it.
The 2 arroys at the LED are just to tell, that it is a LED and not just
a normal diode... sorry, for the mixup...
allcanadian
I got it while you were posting my mistake!
But you are not useing the induction current on approach of the magnet, it does no work. So you only get half the output which is barely enough to break even.
hartiberlin
I just received this from Mervyn
(user Merv in this forum)
as I did send him a private email to his email address, which I can see as the admin
of this forum.
I hope he is really the inventor and I have asked him to post this same
message also on the Youtube site under the Mervace user name, so we know it is him.
So it seems the motor is just powered by a nearby CB radio transmitter,
or did I get this wrong ??
He writes:
"Thanks Stefan. The key to the high efficency is in
that adams motor diagram. .I look forward to seeing
some table top examples of my motor.  my first  set
ups showed there was lost energy  from every  aspect
of the design. Set an AM radio next to it. That lead
to the idea of an aerial pick up to try and retrive
some. Have you guys never played with an SWR meter and
a CB radio. You can light a tourch  bulb with a simple
set up like that. Thats when my table top bare bone
motors evolved to the present sculpture and gathered
dust for so long .Peter from Gremany soon worked out
the principals . As we all know here there is no free
energy but lots floating in the local enviroment. Look
at table top Sterling heat engines.I just had to make
massive amounts to produce a very weak responce Of
course my motor has hidden reeds, signal diode etc but
no battery. I will post the details when i get time.
Im amazed this produced such great intrest I really
must get back to work now Regards
Mervyn."
--- Stefan Hartmann  wrote:
> Hi Mervace,
> I just posted a better circuit for your motor,
> where you can really power an external device.
http://www.overunity.com/index.php/topic,1720.msg18381.html#msg18381
> Please can you try this ?
> Many thanks !
> Gruss / Best regards, Stefan Hartmann
