Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
mikestocks2006
Tao, does it make any difference which way the wires are twisted relative to the magnet motion, and the capacitor polarity?
Thx.
tao
Quote from: mikestocks2006 on November 21, 2006, 12:29:10 AM
Thx.
That is a good question, I would think that it would matter!
Like perhaps for a clockwise twist, the magnet should be south pole outward, or north pole outward.
I will test this later and with better wire, after I hear from the inventor, I mailed him........
Jdo300
Hi Tao,
Great looking model there! I like the styrofoam approach!
I'll be interested to see what the inventor says to you. I wonder where he got the idea to use the twisted wire?
God Bless,
Jason O
smarthousesys
Yes it does look as though this inventor has found some sort of effect but probably not due to any emf induced in the twisted wires. By far the greatest  emf  generated by the system is that as the magnet passes over the solenoid. If it does work choice of components and some sort of transmission line effect are the most likely reason.
tao
Found some information on what those twisted wires could be doing........Remember, twisting wires together allows for a NO-NET INDUCTION CONDITION, this is why the wires in cat5 cables are twisted pair! Also, moving a magnet PARALLEL and ALONG a conductor WON'T induce a voltage/current....So SOMETHING WEIRD is going on....Let's figure it out...
...GIMMICKS...
In electronics
Two wires touching, not connected, possibly twisted together several times, provide a capacitor of very few picofarads as capacitive coupling. This, quite unofficially, is called a gimmick too.
And this was ripped from http://web.telia.com/~u85920178/begin/gimmik-0.htm:
Projects such as my VFH FM Wireless Microphone (BUG) and other VHF projects, use small value
capacitors, under 15pf. Wouldn't it be nice if you could make small value capacitors to order
for the job at hand? But suppose for tuning (the BUG?) you needed a capacitor between, say, 12pf
and 15pf to put the transmitter between those two strong stations! No problem. Take a bit of
single-strand plastic covered hook-up wire about 15cm long (15pf) and fold it
in half, crossing the ends. Hold the loop so formed with a pair of plyers and begin twisting:
Continue twisting tightly until the twisted section begins to curl. Now cut off the loop so
that the top is no-longer short circuited. Strip the ends and you have a perfect vow-value,
high-voltage capacitor of about 15pf - 20pf.
Too many pico-farads? Cut it down to size. I have cut this one down to about 5pf for my latest
project; a VHF FM crystal/controlled transmitter for packet radio using four of these capacitors. I'll
bet you that Tandy would pot them and charge you the earth - if ony they knew how.
Cut off too much and the capacitance is a bit too small? Twist it tighter or roll it up into a
ball - Dead easy! In this way you can also make yourself a preset tuneable capacitor. Let Tandy
try to pot that!
Have fun and "lets twist again" in the 90's, de HARRY, Upplands Vasby, Sweden.
So, basically, this inventor guy is moving a magnet OVER a SMALL capacitor, which is this GIMMICK thing, and this action then CHARGES a larger electrolytic capcacitor........... WA WA WA WHAT?
Poynting flow anyone???
From here: http://www.cheniere.org/misc/static%20poynting%20gen.htm
A Simple, Cheap Free Energy Generator -- But How Do You Collect and Use the Energy?
Let us make very clear that extracting energy from the vacuum is very easy. We will use a device which can be built for a dollar.
Take a charged capacitor, and lay it on top of a permanent magnet so that the E-field of the capacitor is at right angles to the H-field of the magnet. Then the standard Poynting flow S is given by S = ExH, which in this case is maximized for a 90-degree angle between E and H. In fact, the magnitude S of S is just the product of the two magnitudes E and H. The direction of S is at right angles to both E and H, and given by the usual right hand rule.
Well, even by orthodox theory, that is an actual Poynting energy generator. It just sits there and pours out free energy, directly extracting it from the vacuum. There are two dipoles -- one electrical and one magnetic -- continuously serving as an asymmetry in the fierce vacuum flux. Once you pay to make the permanent magnet and charge the capacitor (or use an electret), that simple gadget will extract energy from the vacuum and pour it out indefinitely.
This illustrates how easy it is to extract energy from the vacuum. However, it comes out in nondivergent or difficult-to-use form. So the problem is to intercept and divert a substantial portion of it, or convert a substantial portion of it into a usable form.
That is the problem that the DOE should be working on, with maximum effort.
